Rear lift
Bay Area, CA
Been doing some reading on lift options. I went with the 850J and the L shocks up front and the 863 rears with 315/75/16s
I have a ARB up front and an m12000 hence why I went with the 850J. I am shooting for a leveled look. If I add an ARB in the rear with the tire swing out and all the other stuff they offer, will the 863s not be enough? What is recommended?
I had Js in front and back with 863J's and L socks, but I had a slee bumper, Aux fuel tank and drawers full of tools and spare parts. Springs are easy to change out if you are a little low or a little high. Since you went J's in the front I would do J's in the back, but I like a little rake in the front. Personally, I would call Slee or Kurt or whomever you plan on buying them from and ask their advice. Slee helped me tune my truck just right
We have swapped springs around on my son's rig and ended up with your set-up...850Js + L shocks up front w/ 863s out back. He is sitting .25" lower in the front with Slee Short Bus and 12K winch up front (steel cable) and 4x4 Labs dual swing out bumper in back w/ 35" spare, 3 empty jerrycans and 60" Hi-Lift. He's also got 40 Lbs of thump (sub) right behind middle row in cargo area, OPOR Sliders, 50 Lb custom cross-member/transmission/transfer case armor and 92 Lbs of Roof Rack covering entire roof (tried to list anything affecting his sprung weight over stock configuration).
We also simulated an additional 250lbs in back and 50lbs up front (overland loaded w/ 2nd batt under the hood) and it remained .25"ish lower in the front. For us...it's about as perfect as we wanted. Wish we had started here... For the record, we do have extended brake lines, dropped the F&R bump-stops 1.5" and dropped front sway bar 1.5". Zero issues with front driveshaft so did not change over to DC style.
Good info...thanks for posting
