I'm replacing brakes on 97 FJZ80. Front went in fine...new rotors, pads and caliper rebuilds...thank you CDan. Moving to the rears, how do you pull the hub/disk? FSM says "remove disk"...mine won't budge. I tried using two bolts in the threaded holes but don't want strip or damage anything. How do I get these puppies off?
Release the parking brake, adjust the parking brake shoes so they are all the way loose, then use a bolt through the threaded hole in the rotor, and the rotor will be pushed away from the hub. It took some force to turn the bolt, but it will come off, as long as the parking brake is loosened up. You may have to look in a different section of the FSM, it took me a while to find the correct section, it was easy once I knew what to do.
Lots of banging with the hammer and repeated gentle tightening of the bolts you'll use in the holes. Not on an 80, but I've seen the threaded parts of cast iron brakes suddenly shatter these holes out when people simply start cranking on the bolt expecting it to take that force and do all the work for them. So use your head and be sure the parking brake is off.
