is it common for most Fj40s to not have a rear heater? I’m looking at a ‘79 and it doesn’t have a rear heater. Common?
It may be built into the center console, if it's a late model.
Im fairly certain the console heater was introduced in the1982(edit ) 1981 model year , and went through 1984
the big black square box is a ash tray with a flip up lid , the small black rectangle on the right is simply a Delete cover plate in 1982 , but a on off rear heater rocker switch was either a option or standard in 83 84
anybody else have any input ?
@Simcoe updated his 82 delete with a on off rocker , and has a factory toyota original ash tray in good working order , they tend to break
after 33 Years
So back to this subject...is it easy to install one if it doesn’t have one already??
after 33 Years
@Living in the PastThe switch only shows being used 8/80-1/81 in the US market. My guess after that they went back to the 74-80 models where the rear heater works on front blower switch on high. I plan on installing one of these consoles and heaters in my 79. I have a new OEM ashtray and rear heater switch from a 60 series which looks the same. I would install a resistor to make a two speed motor if the rocker switch from the FJ62 was the same size.
