Rear Heater Delete?
Easy to do the shade tree patch. Piece of sheet metal/license plate/etc on each side and self tappers to secure. Add a bead of sealant to be weather tight.
I used a tip I got from @NLXTACY
A piece of foil faced sound deadener on either side of the hole. I sprayed some rattle can bedliner on the underside of the truck. It’s been there for three plus years no issues. YMMV
I fiberglassed mine. I haven't died from carbon monoxide poisoning yet, so I guess it worked.
Sure @Onur , if you want to do it the right way.........
I used a license plate and a 3M seam sealer.
I did a small stainless steel plate and some epoxy so I didn’t mess up any paint so no rust later on
I used an old license plate with 2 layers of Fatt matt on both mine and then acoutic foam over the whole floor..... works perfectly and huge noise reduction, especially if you take it up the firewall.
Drank a few beers; flattened the aluminum can; taped top and bottom of hole with butyl tape (flexseal-stuff)
@Onur 's OEM plug seem so much more elegant!
Thanks for all the help guys.
After all the advice here I think I’ll dig out the old Craftsman staple gun & a piece of cardboard and just bang that the over the hole. I have some of that really good 3-ply cardboard left from the boxes my Icon shocks came in. I might run a little FIPG (the RED stuff not the GREY) around the edges just to make sure it doesn’t leak but has room to flex.
:hillbilly:
(psssst @Onar: what’s the part number for the good stuff? :smokin:)
These are OEM body plugs for non-US trucks with no rear heaters.
Howdy, the picture is not showing up for me. Do you have the photo or part number? Been searching through parts diagrams with no luck.
I never found the OEM parts. I just body seam sealed in a piece of tin.
Joey over at Wits End is now selling a machined aluminum solution if you have the $$$.
Thanks for the tip. Not sure I want to drop $65 on plugging a hole but it is a nice solution
Yup. I made a promise to everyone and myself that if Wits’ End is going to survive, and thrive, everything I make is a strict 60% gpm straight across the board. I was concerned about the price a little but 30 sold right away so I’m not too worried.
fair enough.
Still want to try to track down that part number for the OE rubber plug though... anyone?
I used HVAC tape on both sides after cleaning really well. It's held up for a couple years without issues.
The tape is like ten bucks per roll and you can use it for a lot of other repairs that are exposed to heat.
