Rear hatch gasket
Oviedo, FL
After slamming my rear hatch closed, I noticed some water come down from under the gasket. I know this can be a common place for rust so I want to get this fixed asap. Do I need a new gasket or can I just have the current one resealed? It is the original as far as I know.
pic is too zoomed in for my eyes, but it is available and easy to install. got mine from beno don't remember cost
I should have been more specific but it's just the upper rear hatch glass gasket. The pic shows the water seeping from underneath it. Can someone verify if this would be the correct part number for it? 68291-60050
But my question still stands if I need a new one or this one can just be resealed/reseated? Thanks.
Just ordered one last month from the local dealer and it was 68291-60050 like you have. I'm replacing a broken glass fwiw. The seal didn't look bad, but it did have a little rust underneath nothing major. I figured I might as well replace it while I'm in there. I'd recommend pulling yours, fixing any rust, and replacing the gasket with new. It's 20+ years old, so it's probably due either way. They're not very expensive either, I think mine was 9x.xx
When you install your new gasket, don't forget to use sealant on it too. I seem to remember the last time this subject came up, Beno said that the Toyota window gasket sealant was now NLA, and he was using a product made by 3M.
Since you are already having some moisture problems under the seal, don't be surprised to find water damage/rust under there, along the edge of the opening. Don't feel bad if you do find it there, as manly rigs also have it there and under the front window seal.
