rear fixed spring hanger fix question
Jakes40
IH8MUD Poser
Winchester,Va
I did this to try and stop the cracked frame problem my question is I was going to bolt it back on with a backing plate inside the frame. Or should I go through the frame with a box section and bolt it in. or just weld it on. Just trying to do this once and like the idea of bolting so I can remove it if I have to.
I've decided to bolt it on I don't think my frame is going to last to long.
any one have a good way to clean out dirt from the frame rails.
Easy enough to duplicate.. Weld the bastage on there..
not that easy to move out of my make shift garage. it has a dirt floor I'm going to pull the F out when I get a 2F I'll pull the frame out then and power wash it then.
Mace now that you put it that way I'll burn it in.
You should be able to source a replaceable frame locally in the valley. If not, let me know and I can put you in contact with some folks here up north. I have to travel to Va all the time (Richmond) and can put one in my company van if you'd like. I'd hate to have someone drive a cruiser around on the road with a cracked frame that depended on a suspension component to hold it together. In the long run, what ever you weld or bolt to that location will fail, and probably when you dont want it to. I'd be willing to help if you can find a frame in the next few weeks.
Rob
I have to talk to some of the guys in CLCC I do bolive thay have an extra I just do not have the time to get it prep it and install it. I'm going to get one and strip it right just not right now. trying toget this done to sell our house in 6 mounths
Why do somthing today when you can put it off till tomarrow.:o
