rear drive line issues
Well I am curious now. :confused:
I can't imagine that a truck with 45k would have needed new ujoints.
Depending on which shop you go to, lots of things get replaced that don't need it. Could have been the PO never had them greased and rather than adding a few squirts the shop saw an opportunity.
Maybe, but I trusted the first shop who did my front. They came highly recommended and actually did fleet work for the city(not that guarantees honesty).
I would feel better if I knew that there are some 80's equipped with sealed ujoints. Otherwise, I'm gonna feel like I was slighted by my homeys.
Any 80 that is running a Toyota U joint either from the factory or rebuilt will have zirc fittings PERIOD.
I hope that is clear now. Draw what ever conclusion you want from the shop. There may have been other things going on. I am commenting on the U Joints.
The only grease fittings on my 80 are on my drive shafts. Every thing else is sealed.
Kalawang
I wonder if they are different in the Phillipines.
When I bought my truck it still had the original U joints. I have since replaced with Toyota and they both have zircs. They are hard to see and sometimes you have to move the truck a bit (To rotate the shaft) to get in there.
The problem ones in there are spicers I believe. I talked to the shop on saterday, but thier driveline guy doesn't come in until 9am monday morning. Does anyone have any further info on the possible need for shims. It's just odd to me that they are loose accross the joint and not onthe rotation.
