Rear door latch failure
Westwood, Ca/Ixtapa MX/Ahwatukee, Az
I went to open my rear door (hatch) and nada I pulled the trim panel & printed the page from my fsm & all appears as it should be (all linkages connected.)
I can open the door by moving the linkage from inside of the door. When I move the linkage inside the door neither latch moves.
Does it make sense that the actual latch mechinism has failed internally?
I'd appreciate any help that can be offered before I buy a new mechanism.
Thanks
Same thing happened to me. Remove the panel with the mechanism on the inside and you will see a broken plastic clip that ties the outer latch in. Couple of bucks at your local Toyota dealer.
Many many thanks.
If it is the same one that I had fail, then expect considerably more hassle than a quick trip to your local dealer.
With pictures...
https://forum.ih8mud.com/showthread.php?t=153224&highlight=hatch+latch
It took me nearly 3 weeks to source one. CruiserDan could get one, but only with the whole latch/handle assembly. Check the "parting out" section. If someone has one with a damaged hatch, they might be willing to send you the part out of it.
Once I had the part it was a < 10 minute repair with buttoning everything up.
Be careful to put the thick part of the yellow plastic into the 5mm hole first, then the metal pin, then snap the plastic shoulder over the rod. This will make more sense when you look at it. Don't try to put the plastic on the pin/rod assembly first then 'snap it in' or you will likely 'snap it off' and need another.
Good luck!
yea I had the same issue and it was just a little yellow plastic piece that had snapped. I was attached to the opposite end of a rod that attached to the exterior lift gate handle.
I guess I was lucky, my local dealer had them in stock. Thats a good pic in the link of the part.
I just took a closer look, it looks like the latch moves a piece of metal that should be hitting a piece of metal that should be sticking out of the part that the rod is attached to the latch.
Does anyone have one available to look at the side facing into the door? If my theory is correct I need the whole latch.
