Rear Diff Rebuild - Pattern Check
Vae Victus
Posting more than I know
Nashville, TN
I'm finishing the rebuild of my rear diff. I have patterned the gears, and believe I have an acceptable pattern, but would like to see if it really warrants messing with pulling the pinion bearing and trying multiple other shims +/- to see if the pattern improves.
As background, this is a full frame off that I'm 3 (slow, yes) years into, taking my time.
I don't mind getting a pinion shim kit, but don't currently have one. Pattern with original shim seems to be good:
- Drive: Centered both horizontally and vertically. Covers about 70% of the tooth.
- Coast: Centered vertically, but towards the inside of the tooth (toe side). Covers about 50% of the tooth.
Love any feedback. First Diff.
New Koyo bearings (CruiserOutfitters kit). Backlash is 0.009". Have not yet set the crush collar on the pinion.
Photos:
It looks like you have real good contact, I say you are good to go!
Just a tip when trying to get a decent pattern - put a glove on one hand and hold it against the outer part of the ring gear for some drag pressure while turning the pinion , it will help to put a clearer, defined mark on the teeth that is easier to read .
I hate crush sleeves and trying to get the initial crush on them , seriously prefer the shim method .
Sarge
If you are doing all this work anyway have you considered using a solid spacer and NOT a crush sleeve? It really is a better way to go.
Dyno
Dyno
I read about them somewhere but don't understand the difference in setup. I'll research that, thanks for the tip.
Ken (Zuk) says I could go 0.005 or 0.006 deeper.
He sent me this, thought I'd document it here:
41201D WASHER, PLATE (FOR REAR DIFFERENTIAL DRIVE PINION)
90201-40551 T=1.05, T=1.05 1 $5.77
90201-40552 T=1.10, T=1.10 1 $5.77
90201-40553 T=1.15, T=1.15 1 $6.05
90201-40554 T=1.20, T=1.20 1 $6.05
90201-40555 T=1.25, T=1.25 1 $6.05
90201-40556 T=1.30, T=1.30 1 $6.40
90201-40557 T=1.35, T=1.35 1 $6.40
90201-40558 T=1.40, T=1.40 1 $6.40
90201-40559 T=1.45, T=1.45 1 $6.40
90201-40560 T=1.50, T=1.50 1 $6.40
90201-40561 T=1.55, T=1.55 1 $6.40
He also said to order the 1.35 thru 1.5mm shims from the list above for my needs.
