rear diff dilemma
Probably half an inch in and out, up and down, left and right.
Your crush sleeve is probable done. Time for a rebuild man. Zuk is the best in the business. ECGS is also very good.
Edit: just noticed you are in that canadia place. I do not know any good builders up there.
I was in the process of replacing my rear pinion seal in my 1990 hdj81 and noticed I have excessive play in the pinion. How much is normal?
Zero, should have preload, likely have a bearing failed.
With that sort of play you will probably be in need of a new ring and pinion, you are lucky it has not had a trip to the dentist already.....
