Rear control arm question
Lutz, FL
I have the slee 4in lift and have not done anything to correct rear pinion angle so I am getting driveline vibes. I saw that man a fre has drop brackets for the rear control arms. If I was to buy the brackets for the upper arms only would this correct the problem?
thanks
did you install the adjustable panhard rod in the rear? i just installed it and did not need to install the control arms. if you need to adjust the control arms have you considered the slee adjustables? this way you can tweak the angle til your heart is content.
You should do adjustable upper control arms if you need them - you don't want to drop one set of arm mounts as they will move off of parallel and you have no idea if that will correct the angles.
How are you sure it is not the front vibrating? Do you have caster correction plates and the DC shaft up front?
You need to install the panhard so you don't have the side shift to the axle alignment, which also creates a compound angle for your driveshaft, and then you need to measure your u-joint angles at the t-case and angle end to see if you need adjustable upper arms to rotate the pinion and bring the u-joints back into alignment (+/- 1 degree max ideally).
Ya I have the DC front shaft and caster plates so I guess I need to take care of the panhard first.
thanks
I doubt it's being caused by the panhard given the length of the rear driveshaft and lateral shift amount of a 4" lift. You should pull the front shaft and drive with CDL on to make sure it is the rear driveshaft before you spend any more coin.
If it is in fact the rear shaft, again make sure you do the adjustable uppers.
:confused:
why do people do this piece-meal?
Anyone know what length new lower arms would need to be?
thanks
You can lengthen the lowers and/or shorten the uppers, pick your poison. They need to be modified by the amount that's required to correct the pinion angle for the type of driveshaft and amount of lift on your truck.
The advantage to the Slee threaded upper is that you can fine-tune it to the exact position you need.
Inverness welded these up but if you can afford Slee's 'bolt-on' ones, I would do that. All finished and powdercoated.
They only sound expensive but they are a good deal.
Also check our continuing buildup thread in "my wip" in my sig line and also Inverness' pics
http://flickr.com/photos/80_on_inverness/sets/72157600184098497/
and Roberto's
https://forum.ih8mud.com/showthread.php?t=152526
I didnt do the panhard. Did that stop yours from vibrating? I was just looking to see if this way would work since its cheaper and easier. Heres a link http://www.man-a-fre.com/pa/4plus80seriesdropbrackets.htm
thanks
i did the springs, shocks, slee castor plates, front and rear panhards and DC driveshaft.
no vibrations what so ever. drove it home perfectly. the only thing i had to do was upgrade to a longer drag link to straighten out the wheel...
Lengthen the lowers and you change how the tire stuffs in the wheel well. Probably no big deal unless you are pushing clearance with large tires on a smaller lift.
Ok so if I pull the front shaft and it gets rid of it whats my next step I think I have done everything suggested for the front? By the way my set up is the slee 4" and going to be running 35s the driveshaft is stock in the rear.
thanks
thanks
Now I recommended this in post #6 :flipoff2:
You said you are running the Slee caster plates and DC shaft. Is the pinion on the front axle pointing exactly parallel to the driveshaft (zero degree u-joint angle)? Is the DC shaft from Slee? If you have the correct angles, then any front vibes would be due to driveshaft balance or some other issue. You'd need to take the driveshaft to a good shop and have it checked out.
But you need to do this - it is very difficult to tell by seat of the pants whether or not you have a front or rear driveshaft issue because both are felt at the t-case.
Do you know how to measure u-joint angles? You really need to do this, because you don't want to throw money at parts if you haven't assessed whether your angles are aligned or not. Good angles with vibes may mean a worn u-joint, which is something a $500 set of control arms won't fix. The diagnosis of angles will only cost you a $10 gravity protractor from Sears and 15 minutes of your time.
This is a simple and invaluable skill for anybody who owns a modified 4x4, because you can spend a mint chasing driveline vibes if you don't understand how to measure the angles and how each style of driveshaft works to run without harmonic vibrations.
Cause Im trying to be a cheap bastard
no problem with that...but how about waiting until you get enough bits and pieces together first before slapping things on?
:D
