You should do adjustable upper control arms if you need them - you don't want to drop one set of arm mounts as they will move off of parallel and you have no idea if that will correct the angles.
How are you sure it is not the front vibrating? Do you have caster correction plates and the DC shaft up front?
You need to install the panhard so you don't have the side shift to the axle alignment, which also creates a compound angle for your driveshaft, and then you need to measure your u-joint angles at the t-case and angle end to see if you need adjustable upper arms to rotate the pinion and bring the u-joints back into alignment (+/- 1 degree max ideally).
