Rear carpet removed solution.....
I've also considered this, but haven't started on it yet. I'm curious to see what comes of this thread!
Do some searches for sound deadening, floor coating, and herculiner. It's been done before.
If you dont care for the skin on your knees roll on the Herc'
Id go second skin then u-pol via schutz spray gun for a smoother surface if going all out and planning to crawl around back there any.
Alkalinetrio did this but unfortunately passed away in accident. I see his rig somewhat regularly and it looks to be holding up well albeit not with daily use/abuse
There are a couple other theads as well
I want to see what becomes of this thread. I've thought of lining the inside, or building a diamond plate liner.
Did someone recommend the OPer do a search?....
Nevermind, that a****** already chimed in.
Depends on your tool and equipment availability. I recommend Raptor Liner. I painted the exterior of my cruiser with it. If you have the means to spray a coating, it's what you want, elsewise, monstaliner can be rolled on. From what I understand, the texture is a direct result of what you use to roll it on. Therefore, you could get it smooth enough so that it's not harsh on body parts.
Of course that a******* already chimed in. Because you should ALWAYS do a search before asking the simple questions. If I want to know about something, I do my research. I don't just blurt out every thought I have without SOME intelligent thinking.
Oh, but I'm sorry, You advised him to use tools and use Raptor Liner. You see....If he was smart enough search for: "lining the inside of my 80" or "coating the floor of my 80", I'll bet his questions would have been answered. However, you were kind enough to answer his question.
But once you get old and crabby like me, you just tell the little bastards to "DO A SEARCH!!!" and "GET OFF MY LAWN!!!!"
I thought about this but put vinyl flooring in instead. It's softer.
I rhinolined the inside of a 40. Hated it.
Depending on the product, the off-gassing smell can be powerful in an enclosed space for months. Do your research.
Definitely concerned about the smell.....especially with Herculiner. And I'd like to be able to crawl around if necessary. Not to mention the kids will be back there at times.
Maybe a hard plastic liner like they have throught the FJ Cruiser? Use adhesive to secure it to the bed.
Why do you want to do it? What's your goal/purpose?
Bought it with the rear carpet removed and I like it. Normal wear and tear stuff like hauling trash to the dump, camping, kids, dog etc.
I don't think I would use Monstaliner as the finished interior surface because it has a pretty smooth finish that has a satin sort of sheen to it and I believe certain cargo items would have a tendency to slide on it.
Why not buy a rear cargo rubber mat? Husky liners, Weather Tech, and others. Google it.
I personally don't think I would like it. Noise, comfort, etc. Maybe if it was a dedicated work truck of sorts. But, nah. Even something like @LS1FJ40 used for his sleeping platform (the tile walking floor pads things) I think would be better.
I used them under a rug for now so I used the cushiony ones. But the more rubber like ones would work too. To me, I want a little cushioning back there. The vinyl flooring I installed from @reevesci aka Trail Tailor is the perfect blend of functionality and finish. Plenty of cushion but hit it with the blower and the dust is gone.
It only takes a moment to give informative information. Something other than "use the search" may point them in a direction other than weeding through countless posts of bull****.
The cargo area carpet in my 60 was trashed so I cut it out. I didn't really want to go the liner route, especially because I would have had to either remove or cover the tar sound deadener which would be a pain in the butt. I found some cheap 1/8" thick diamond plate rubber matting and cut it to fit using the old carpet as a template. It only cost me about $40 and about 10 minutes to cut and install. Hard to beat the practicality, price, and lack of effort required.
I was considering this stuff, marine vinyl flooring. I have a customer that I powder coat for that sold me a chunk (they use it on the paddle pontoons they make) and I did my platform with it. Very nice stuff, good grip but still soft.
Woven Marine Vinyl Flooring $445.00 - $1195.00
The flooring I got was by the foot on a 6ft roll. Around $10 a foot. Lots of sellers out there
