Rear caliper hanging up?
STL,MO
Anyone have any problems with a rear caliper intermittently hanging up?
what year is your truck? discs have calipers that could stick and yours may need to be rebuilt.
cleaned and greased the slide pins...shot a little WD behind the boot. Put about 600 miles on it now and it hasnt returned :) Got a caliper in plastic wrap sitting in the back just in case though.
How can you tell if a caliper is sticking?
Sticking Calipers
You can tell if the rear calipers are not floating as they should because the pads will wear unevenly the wear will be on the piston side (inside pad mainly) as it is forced onto the disk. The outside pad will not have any force exterted on it as the slides will be seized.
Front caliper calipers can also give problems when they seize pistons in the bores of the calipers.
Same symptom long term although you should notice uneven braking from the fronts due to the steering pulling towards the side that is doing most of the work.
Cheers
Calipers do stick. WD-40 is not the cure. Take it from an old mechanic. Most brake installers do not lube caliper slides. I insist on doing it every time the pads wear out. I get paid 1 hour to put pads in, and I earn it! I do it right. I clean out & lube the calipers. Every time. If your brake man does not, he should be fired!
Take the slides apart completely. There are very few parts involved. Clean off all rust and all old lube. Do not be afraid to use a power wire brush.
Then use one of two lubes. The red Valvoline 600 degree grease is OK, but I prefer the Permagasket aluminum anti-sieze lube for them. The stuff that is used to keep bolt threads from sticking. Honda and Toyota both recommend it for brake caliper lube. Lube the slide areas well. Also lube any part of the brake pad and backing plates that might move or vibrate. Then reassemble the brake. It will be O.K.
I personally have had trouble with anti seize on the slide pins. I was taught to use white lithium and that's all I use now. I've also have had to clean out the holes as well. For this I use a 3/8" drill bit. I use some light oil on the bit and work it into the hole by hand. Once the dried up crap is oit of the hole I do my best to clean the rest out with a rag.
At times, while driving I get a slight almost scraping sound. Nothing harsh. When I press on the brakes it goes away. A quick visual says the rotors are in good shape and pads are still in good shape. I'm thinking that the piston(s) are sticking and at times making contact with the rotor causing the noise. Is this the same thing as the caliper hanging up???
How are your caliper bolts doing? The scraping could be the caliper on the wheel. Are you running OEM brake pads? Scraping, from my experience, is not normal with the OEM brake pads.
I am running OEM pads. I'll check the caliper bolts when time permits. Fire burning all around in my area. Though, you don't think it's the pistons sticking?
What is "caliper hanging up"???
I have the same thing happening right now. Press the brake pedal and it goes away. Light scraping metal(??) sound as if something isn't releasing fully. My brake idiot light came on too.
I found out with mine that the right front calipers were sticking. Specifically the outside calipers were sticking. All looked good from the outside, but the inside calipers were doing all the stopping and had ground down into the rotor.
Best to give it a thorough check.
