rear bumper build saturday
Dirty Toad said:
yeah, i am gioing to need to see some pictures. i don't think that I am any more confused than before. bit I don't think that made it much better.
Bring on the pics PLEASE!
here is the original step design on my 60
i only have two outriggers on my sliders welded to the frame.
still works well for a hack job ;)
cool! that is what I thought you were describing, but as you could tell, I was not too sure. could you show me the others as well?
thanks
That bumper redefines the words "heavy duty." Very, very nice work. I am continually inspired by the work people do and post on this forum.
thank you very much sir!
i also just hook up from treerootCO the rear frame rails from a junker 60 sitting in his yard.
as soon as i go cut it out, bumper will go into production and hopefully not take as long as chris's :frown:
jim
thanks
BTW, try searching under "sliders" or '2badfjs" you should be able to pull up quite a few post with pics.
i've got uninstalled sliders at home if you want pics of those.
let me know
Here is a pic of his sliders without the step
So what did you end up bolting the bumper to? It appears that the original bumper mount needs to come off the bolt it up right or did you drill more holes?
2badfjs said:
saturday/sundays pics
after removing the factory bumper, we had to make a notch in the x-member so the 3/4" plate would slide in the frame
using the factory bumper brkt holes you have to cut the heads off the rivits and punch them out.(sawsall works the best for this)
we unded up having to cut the 3/4" plate down to length,from 14" to 9"
we then counter sunk holes in the end of the plate so the plate would go over the rivits from the rear body mount.(i made the mistake of just counter sinking the holes, instaead of making a grove in the plate so the bumper would slide off the frame,that was sundays project :doh: )
drilled holes, cut 45's,tack welded plate, trimed off the ends of the bumper for a sleeker look ;)
we spent about 8hrs on this saturday and a couple sunday fixing my mistake.
i've got eight pics of what we have done so far and as i finish this up in the next couple weeks, i'll post more.
thanx for watching........stay tuned :D
drilled out the rivits and used the original holes from the stock bracket
2BAD,
That bumper is looking AWESOME bro!!! By chance...do you have an approximate weight on it?
I cant wait for the pricing to come out!!!
Great job...damn, I love your designs for your s***!
Chicago
chicago said:
2BAD,
Chicago
It probably weighs about 150 right now with the tire carrier.
and i'm not even posting in the other thread.
it's not nessasary
no need to spend that much $$ on quality. ;)
Don't know if you know this yet, but what will the measurement from the bottom of the tailgate lip to the outside top edge of the bumper--ie, how far will it stick out in back?
Nice work, by the way.
Timoss
88 fj62 TLCA
God dam there has to be a lot of work into that bumper...
Q:Don't know if you know this yet, but what will the measurement from the bottom of the tailgate lip to the outside top edge of the bumper--ie, how far will it stick out in back?
it just sits out far enough that i'll have room to mimick the end cap so it will just wrap around the corner.
i will also build in some stealthy 1/4 protection :D
Q:THE MAN.....edit ;) there has to be a lot of work into that bumper...
you dont have to tell me.....
trial and error
the end pieces are all individual pcs. the next ones i do will be one piece that wraps up the ends..
gettin there :D
