Rear Bump Stops
South Central NH
On my 93 Landcruiser the rear bump stops have no rubber on them. It is just a metal bracket about 2 inches proud from the frame. I thought my rubber portions may have deteriorated and fell off before I purchased this rig but when I look at my wife's 97 her brackets look the same ie with no rubber. Is this normal? I need to install some bump stops/extensions to stop tire rubbing but I would think I need to take measurements from a rubber contact point opposed to measuring form the metal bracket point. Is there a source for bump stops with rubber or a different application to source them from?
it should have rubber. my 93 had the same issue and i pulled some from a parts rig to replace them with.
On rust buckets, the rust creeps under the rubber pushing it off. The fix is to replace the bump stop.
That's what I figured would be the case but my wife's rig was from the south and there is virtually no rust on it even after running the past 3 winters in the northeast salt.
So should I just find new/replacement bump stops and then find a suitable extension or is there an option to buy bump stops with a thicker rubber to serve as the "extension?"
I have searched a bit but it seems to get crazy for some of them. I am looking for the down n dirty fix. They are bump stops on a woods rig so paying $200 is neither a choice or an option.
We have used factory ones from other rigs, harvested on pick and pull runs, but that isn't likely to be a good option in rust prone areas? Maybe bolt an aftermarket stop to the bracket?
