Rear brakes
Edmonton AB.
Hi New to the forum and looking for some help with the Rear brakes on my 91 Hdj81. Over the winter i installed an Ome 2.5 lift and made the suggested adjustment to the brake proportioning valve. not being satisfied with brake performance i adjusted further moving the valve body down. Kinda forgot about things for the rest of the winter and after swapping out my studded winter tires for my summer tires i noticed that the rear brake discs had very little wear and the front were wearing heavily. Is this normal for an 80 series or do i still have some work to do? Thanks. Scotty
You moved it the wrong way. LSPVs in a lifted vehicle need to be moved up to simulate the body getting closer to the axle housing.
Thanks but doesn,t moving the valve body that is attached to the frame down, bring it closer to the axle simulating increased load over the rear. and also yes i have moved the adjuster rod on the axle housing up. I beleive that i have made the valve give the maximum force to the rear axle as the valve has bottomed out in its range of movement . do these become plugged of fail somehow?
Yes, Dan just spaced for a second and thought you were talking about the axle end. You and unbolt the axle mount and mount it with just the top mount on the axle and bottom mount on the frame to get a little more, adjust the valve all the way down, and use up all the thread on the adjuster.
