Did I diagnose this right?
Rear passenger side wheel hot and smells burning. Put in new brake pad not long ago. Car is hardly driven and not by me so this may date back to then. I pulled off the caliper. Pins are loose. Piston moves ok. There is rust stains on the ouside of piston under rubber boot. Clean piston as best as possible and reassemble. Wheel runs freely. Apply brakes and can’t turn wheel anymore. Open brake fluid drain valve to releave pressure. Still can’t turn wheel.
Based on mud research, thinking the piston is stuck on. Considering rebuilding and or buying a Toyota reman.
Make sense?
Thanks.
Make sense?
Thanks.
