How can I make room between the rotor and the brake caliper housing so I can install the outer rear brake pad? The inside pad is in with no problem. I just can't get the new pad to fit in the little space between the rotor and the brake caliper housing. If the new brake pads was thin enough, no problem. This probably an easy solution but anyway, let me know. Thanks
's 80 she went metal to metal (did that on the fronts as well...neither end had pad wear indicators from a PO brake job) so the rotors had to come off which dictated having to remove the torque plates. Not terrible but limited access to get the torque wrench and socket on the bolts. But, once the torque plates were off, getting the old pads out and the new pads in was super simple and I replaced the pads supports etc as well. Rest of the reinstall was the same as on the LX other than slipping the torque plates with the pads on first and torquing the bolts down.
