Rear brake line position
Florida
could somebody take a picture of the rear axel with the brake lines location from the flexible hose to the wheel cylinders and post it?? I'm rebuilding the drum brakes in my 1970 FJ40 and I'm having a hard time positioning the brake lines. Especially the t fitting. The manual diagram doesn't show much. Thanks in advance.
My '73 has "T" fitting held to housing by vent. Short line to passenger side, long line to drivers side over top of third member.
Yes my is that way too, does the short line bent over the t fitting in direction to the wheel cylinder? and does the long line goes around the differential?
I’m doing the brakes on my 67 so good timing! Let me know if these pics are what you need.
Yes!!!! Great. thanks a lot!! do you have one that shows which hole in the banjo? Thanks
@rainingagain!! Are you going to replace yours? My were almost as bad...but I restore the original ones. A lot of "elbow"!! If you going to reuse yours, be very careful when you remove the lines...they will be rusted solid!!I found that ATF/Acetone mix its the best!! and patient...
Passenger side
Driver side
Just pulled tires off over the weekend to get started on this.
I’m a little disappointed in the amount of rust. I planned on using the original ones but we’ll see how it goes with cracking them loose.
Yeah, thas what I need!! Thanks again! Will help me a lot. After looking at the pictures of your car you will need to apply heat at those parts and I don't know if its going to work. I got a place that you can get the 9mm nuts brake lines( your car has 9mm right?) and with regular 3/16 brake lines, you can make your own lines.
Tube Nut 9mm x 1.0 3/16 SAE Fitting
$5.59
SS7031 is 9mm x 1.0 3/16 SAE Fitting Stainless steel Tube Nut used on 3/16 in OD Tubing in. Classic Tube manufactures only the highest quality USA parts, so you can get the job done right the first time.
Toyota Land Cruiser FJ-40 Caliper Inlet Lines & Transfer Tubes -1963,1964,1965,1966,1967
$69.99
TYD1008-OE is a Rear Caliper Inlet Lines made of specifically for the Toyota Land Cruiser FJ-40 manufactured in our US facility using only the best American materials and latest technology.
Toyota Land Cruiser FJ-40 Caliper Inlet Lines & Transfer Tubes -1963,1964,1965,1966,1967 quantity
Add to cartCompare
SKU: TYD1008-OE Category: Land Cruiser FJ-45
Good luck and thanks again!!
I’d not recommend reusing +/- 50 year old rusty brakes lines. They might work until you’re barreling along at 50 mph and your brake pedal suddenly hits the floor like a brake pedal.
I’ve only had this happen to me once. Fortunately is was at .5 mph. 6 months prior we’d paid a shop to redo the brakes on our ‘77 farm truck (just after selling the farm). Both rear cylinders failed and puked brake fluid on the rear Shoes.
I’ve always been thankful they failed the first time I hit the brakes on the way up the driveway, rather than on my way past the nearby park or after I’d got on the highway :eek:
