I am finally done wrangling my pics.....so here goes.
My 60 does not have the threaded inserts in the rear door pillar so this covers that problem as well.I applied an idea a fellow mudder suggested a while back. I forget who it was to give credit to.
I purchased belts and hardware kit from:
BEAMS Retractable Lap & Shoulder w/12" Push Button Recieving end
In order to attach and reinforce the pillar nut I epoxied the nuts to a fender washer supplied in the kit.
The fender washer is too large to fit in the pillar so I trimmed it with a cut off wheel.
I dropped a line into the pillar thru the hole with a small bolt as weight. Be sure to fish it out the larger opening to the side. I found that the pocket directly below the pillar wouldn't pass the nut/washer assembly.
I applied two generous balls of epoxy putty and pulled it up. I used a washer on the end of the string so it would be less likely to get stuck. I did a couple test runs before applying the putty.
I cinched it down with a bolt supplied in the kit.
Clean out threads as best you can. I went ahead and attached the belt to the pillar while the putty was soft to be sure there was no issue later.
After a couple of attempts to mount the retractor end, I decided it was best to drill a hole and place it where I thought it was best. I chose the location by aligning the belt with the pillar.
You can access the back of the bolt thru the small opening. This way you can back it with a fender washer. It is slightly tricky to get a wrench in there but do-able.
Locate old retractor behind seat back, under carpet and remove. Use this point and original hardware to attach the fixed end of retractable belt. Feed it under the seat back from in front of the seat.
Remove old short/fixed belt and install new one with out plastic cover. (Be sure to order 12" version) Use original hardware.
Thats it. I will be fabricating a couple of clips to retain the belts so they dont catch on the seat lock when you lay it flat. But until then my kids are safe and the wife is happy.
I hope this helps. And by the way the charcoal color matches very well.
