rear axel woes
My $500.00 brake job has just turned into a $1700.00 rear axel job!Ouch! Does anyone have any thoughts on Slee's rear axels? They seem to be a little less expensive, and I would hope just as strong if not stronger than stock. I don't do any hardcore offroading, my cruiser is my work truck, and usually loaded with several hundred pounds of woodworking/carpentry tools. Are the Slee axels overkill? Thanks, Andrew
For a daily driver... probably. But I'm sure you could find some way to get that thing to where it belongs at some point, right? :hhmm::idea:
My first question would be what is wrong with your current rear axles?
If you mean the Poly Pro axles Slee sells they are considerably stronger than stock. Cheaper and stronger than stock sounds like a deal unless you can find some used OEM ones in the classifieds here.
I am a little bit confused now, do you have a semi float or full float rear? It sounds like you have a semi float and the only axles I am aware that Slee sells are for the full float axles.
Semi Float, C-Clip, no repair bearings that I am aware of...
Even in the semi-float there are still bearings to replace. One bearing for each side. Also curious on what's wrong with your rear axles? Did the bearings leave wear marks on the axle?
Poly Performance makes a rear axle shaft for the semi-float for a FJ60, not sure if it'll fit the FJ80. I want to say yes but never looked into it.
Correct. Bearings and seals are pressed into the ends of the tube. If your axles are done, then get another set at a wrecker or cruiserparts.net. I have a spare set in the event I need one.
"repair bearings" for a c-clip axle that have a bearing surface on the axle shafts move the location of the bearing over so in theory the repair bearing rides on a undamaged portion of the shaft. Repair bearings are pretty common for GM C-Clip axles but I am not aware of one for a LC.
ahhh ic. didn't know about those and thought you were suggesting there were no bearings.
