- Thread starter
- #41
I went through and measure the ohms on the + and - side of the primary coil.Not sure what you did here. Please explain.
I measured the resistance at the secondary coil resistance.
Both readings were within the specs.
Did you check for spark from the coil?
Did you test the dissy pick up coils?
Good on you Gavin. Looks like you got it all sorted.
Quick question: On this last go around when the truck stalled while driving, was the CE light on after it stalled and was not able to restart? If it is still in that condition please check for spark. I'm curious to know if the AFM can cause a condtion where the CE light is on and there is no spark. Alternatively, she could have stalled due to fuel starvation as the AFM also runs the fuel pump.
You also mentioned, "I switched out the ignitor for the one from the LS400, and tried starting it. No go, but code 14 went away."
Code 14 is a missing signal from the igniter to the ECU. Curious to know if you old igniter ****ped the bed in the midst of all this.
In any case you've got it on the run and I learned something new from your misfortune.
I checked for spark at cylinder #1, then the main wire at the cap, then at the coil.
I'll check the pick-ups tonight.
On a seperate note, I have some ignitor info
The stock one on the 1991 LC is 89621-30010, this was superceeded by 89621-12010.
This old PN has a large "125" on it, while the new one has a large "123" printed on the body. Same size, mounting and plug, and mine came from a 1990 Lexus LS400...and can be had from many different Toyota vehicles.
