Which onboard ohmmeter tests would these be; I'm confused.
In the FSM.
Unplug the AFM connector, resistance between this pin and that pin should be..., etc.
Okay, re-re-soldered the AFM connections and checked continuity...everything functions.
The vehicle will fire, and run just fine, still showing CEL code 24 and 32.
I am going to disconnect the battery to clear the codes and see if they come back.
Fergie, got your PM.
IME, the AFM can, in fact, cause a no-CEL issue, that was the case in my buddy's truck. There was a piece of metal lodged in the AFM causing a short....how it got in there is still a mystery to me. When I removed the offending piece of metal, the CEL lit up like it was supposed to.
Also, the fuel pump on these trucks is pretty much whisper-quiet. I cannot hear mine for the life of me.
In my case, this was true as well.
With the solders broken, there was no CEL on. Once the repair on the AFM was done, the CEL came on immediately on the dash.
Now, as I mention above, I have Code 24 and Code 32, IAT sensor signal and AFM sensor, respectively.
It is late, so I will get back to it tomorrow, but my plan is to leave the battery disconnected overnight and then check my hose clamps in the morning. I think I forgot to tighten one around the AFM outlet side.
I'll check again tonight and see if I can snap some decent pictures of it.Something is amiss with the AFM. Are your repaired connections solid, not touching each other?
Back to the beginning...
Is the CE light on when key is in the ON position? No CE = no sparky.
Did removing the plug from the AFM effect the CE light?
If the CE light is on then the EFI circuit is energized and you should be getting spark. You need to check for spark. Possible bad igniter/coil. Igniters can go horribly intermittant and there is no check in the FSM.
Another possibility (remote) is the field coils in the distributor. There is a check procedure both in the FSM and on my website.
Again, check for spark FIRST.
Checked the for spark per the FSM and am getting the correct Ohms.
