Hello Everybody,
In my 89 hilux ln106 I have had a strange vibration latley....
See if this makes any sense to you guys:
-Happens only in fifth.
-At 2400 - 2500 RPM, Tried shifting into fourth and driving at the same speed... no dice.
-No other RPM or Speed.
-Does not happen in Neutral.
-Sounds like it comes through the shifter, and seat, but not particularly one side, both and from the rear of the truck.
-About 3-5 beats per second, does not sound like a tire.
-quite loud...
-Checked all U joints, one is a tad loose, but I mean very small, maybe a 64th of an inch movement. All others are good.
-Steady bearing moves up and down about a 1/4 of an inch, very sloppy.
-My rear Spline pukes grease... Grease it daily and still takes like 10 good pumps of grease.
-Output Plate has no play, tightened that about 5 months ago.
-And last but not least, sound goes away if I let off the accelerator pedal, and comes back when I push the accelerator again. Driving me nuts, and I don't want to damage anything.
-Rear Diff, Front Diff, Transfer Case, Tranny all have correct amount of oil.
-Joints are grease.
-no loose bolts....
Does it matter how the rear drive shafts are bolted to the tranny and diff? Are they supposed to be offset?
Think it might be the Steady Bearing????
Thanks
Brodie
-quite loud...
-Joints are grease.
-no loose bolts....
Thanks
Brodie
