Really need your help
A mile higher than most!
This is the deal. I bought a 92 80 and it ran great (as far as 3fes go) brought it into Charleys in Boulder for my 60 or 70k service. They F-ed it up and didn"t get all the air out of the coolant system and as a result got an airlock got hot and blew the HG. Gave those saps the benefit of the doubt and had an inframe rebuild done upon their suggestion. I moved out of state had a knock called Charleys they told me to try Seafoam. The knock has now become a hole in the side of my engine with a pissed off wife in my house. The mechanic where I live said it was a wrist pin that let go and caused the grenading.
So the 3fe is dead and not even worth its weight as a core. My question is what should I do.
As I see it I have three options
1. Put in a reman 3fe for about 5k or so with a 100k warranty (wife loves that idea)
2. 350 with a 350 turbo for 8-10k.
3. Sell it which I have a hard time justifying (and as a LC owner we can justify anything)
Also will a 93-98 engine bolt in or will their be more to it.
So I need help figuring this out:bang:.
That grenading would by hydro lock. The wrist pin gave out because it can't compress a liquid and the weakest part gave up.
Also, I would look into legal channels personally.
Also consider what you bought it for and what you have into it. You may be better of by cutting your losses.
The vehicle is nowhere near worth enough money to justify spending several thousand dollars on another 3FE. When it's all done it still won't pull the skin off of a custard and it will be worth about half of what you spent on the motor.
If you put a V8 in it it will be more interesting and a lot more fun to drive.
It's not worth the effort to try to put a 1FZ in it unless you can get an entire donor vehicle to keep picking parts off of as you do the build.
Sorry to hear about this misfortune.
Pardon my ignorance, but what is an inframe rebuild?
It is my understanding that if there is an air bubble in the cooling system, it will purge out through the radiator cap if it is functioning correctly, before any significant heat builds up. Is that correct?
I would probably go for the V8 swap especially if you can do the work yourself. If this isn't an option, I'd probably scrap it as a parts truck and but my losses.
pull the head drop the oil pan rebuild the motor without removing the block.
And does he Bondo the hole in the block, also?!:rolleyes:
Sorry fourtrax, couldn't resist---:hillbilly:
Edit: Mybad, just noticed what jfz80 was prolly case.
pretty sure hes answering the previous poster's question as to what is an in frame engine rebuild.....
Sorry to hear for your troubles. If legal options were there, id pursue those. If not most likely part and scrap it as you can get a newer !FZ equipped (or 3fe if you so desire) for less than any of your repairs.
