Real Time Help!!!!!
VA
My wife goes to start the truck this morning to take the boys to school and she turns the ignition.... click,click,click,click! She said yesterday it hesitated to start, but it did. This morning, it just clicked, repeatedly. So, I rush home from work, clean the battery posts, jump it off and it starts! Now, what could it be? Should I still have had to jump start it if it was just the battery terminal? The battery is not even a year old yet. Please help. I don't want this to happen again. I can't keep leaving work. :rolleyes: Thanks!
well, if it started fine when you jumped it, that suggests a bad battery or bad terminal connectors or poor connection. Less so the starter.
Just charge it up and check the voltage to try and determine if it's good. Or take it to a shop to check it more seriously.
Sounds like what happened to mine when the starter contacts were going...mine started "sporadically"...thus, I thought I needed a jump...when it was actually my starter contacts. I would trouble shoot and start with the battery, terminals, connections, starter, etc.
ONE NOTE: My positive battery terminal was replaced back around X-mas.
SECOND NOTE: Toyota Stealership replaced my starter about 5 or 6 months ago.
Now, the alternator? I thought if it goes "click" repeatedly, it is not the alternator. I don't know if this as fact, just what I read on another post but please, correct me if I am wrong. So, how do I check the alternator?
A quick test of the alternator is easily done with a volt/ohm meter.
With engine running, you can take the ground lead of the V/O meter and touch it to a known good ground, then take the positive lead on the V/O meter and probe the "output" (batt) post of the alternator.
I don't have my manual in front of me....but most healthy alternators will be putting out between 13.7 and 14.2 volts.
sounds like a bad starter to me
check the connection between the positive cable and the starter. If that is loose/corroded, it'll act just like bad contacts.
Listen to e9999. It is likely a bad cell in the battery or loose connection.
If the battery is kinda new and the starter is 6 mo old I would start with battery connections. From there I would go to a battery place for a free battery/alterator test. If those are good look closely at the starter. my intermittent starting issues were eliminated with a new(rebuilt) starter.
:cheers:
i would check the alternator first. that's what it sounds like to me if the battery is fairly new. when my starter went out a few months ago it didn't make any clicking noises. it just plain did nothing when i turned the key, then it would hestitate and crank. a click, click, click sounds like a dead battery due to a bad alternator.
Sounds like what mine was doing before I rebuilt the starter. If it's not under warranty from the dealer, call CDan and get the starter rebuild kit. Rebuilding the starter is very, very easy and only takes a half-hour if you take you time. Removing and reinstalling the starter, well, that's a pain in the ass. Find someone with small hands. It took me several hours to remove and reinstall.
battery, alternator, starter, all these are possibilities.
The way I look at it, you start with the easiest thing to check. In this case, I think that would be the battery charge. Either it's there or it's not. If it's not, then it's the battery internals or it's the charging level (alternator). Both easy to check with a voltmeter, at least a first shot at it.
If it fully charged and in good shape, then I would check connections next, again with a multimeter. Finally, get to the starter, since that's the hardest thing to quantify.
We're good, but not that good. I have no idea what vehicle we're talking about.
DougM
If your battery cables were slightly coroded it's possible that your alternator couldn't charge your battery as you drive because of this corrosion. You have probably already fixed your problem by cleaning them.
