Real time help
S. Ontario
I have an antenna mast that was broken during an ice storm last winter. I bought a replacement mast BUT the original toothed cable is stuck inside the motor. I went to take apart the motor using this link:
http://www.spokanister.net/vehicles_antenna.htm
I did get the bracket off BUT the screws holding the motor together are stripped and there is no way I can crack this thing open. I did manage to turn one of them but it does not release. The only one I can get out normally is the center one. The others are "frozen".
QUESTION: Should I drill out the screws?
I'm leaning towards doing this:
https://forum.ih8mud.com/showthread.php?t=149845&highlight=flexible+antenna
LAST QUESTION: If I get the Napa antenna (YES, my local NAPA has one), do I use the OEM coaxial cable that goes back to the head unit (radio) as a fish line to guide the new coaxial cable through or do I have to take apart the dash?
Thanks in advance.
:beer:
Its hard what to tell you with a stripped bolt as they can be trickey. Did you use the correct bit head to unscrew it?
PB Blaster might loosen it up.
I have had the best success with reverse drill bits in the screw.
I just did this a couple months ago only to find out the cable was not in fact in the motor :doh:...Oh well the PO had no idea but I assume you know that cable is down in there.
I cannot remember now, but can you push on the screw from the opposite side while turning it? Looking at the pictures it looks like you should be able to. Also, there is that black "goop" that, even after you have the screws out, holds the motor together.
My suggestion, since you already have the motor out would be to do what it takes to get those screws out...Reverse bit like Romer mentions or just drill them out entirely and then bolt that sucker back together and seal up the seam with something. Maybe it is just me, but the thought of having to thread a new antenna into the dash sounds less than fun.
I've read threads where folks found another antenna lead behind there dash and figured out that a PO had replaced the motor and whoever did the install just hacked off the antenna lead rather than trying to pull it out. I've never done it so I don't know if it as big of a PITA and it is made out to be.
Good luck :cheers:
Thanks for the advice. I think I will go ahead and drill out all the screws that are misbehaving (these are Philips head metric screws hiolding this thing together - I never have any luck with the Philips heads - Robertson, Torx, Hex, are way better - Philips heads should go the way of the Dodo bird). The screw holding down the grounding wire will turn till the cows come home and it gets dizzying watching it because it won't come out to play.
If I end up using the rubber mast, I will likely route the cable through the firewall in a far more convenient spot (I hope) than that used in the OEM setup.
Thanks again.
The flexible antenna is in from NAPA (part # 730-4855 ).
The OEM motor was locked tighter than the skin on Ricky Ricardo's conga drum so out it came.
Not a tough job, just looks ugly.
:beer:
