Real Time Help: Throttle Position Sensor
Seacoast NH
I'm following the FSM and checking the TPS while I have it off to replace the VCG, Spark Plug Grommets and PCV Valve (also sandblasted and painted the valve cover and checked valve clearances).
In step 2B of Throttle Body Inspection (SF-31), the FSM says to check that there is no gap between the throttle stop screw and the throttle lever when the lever is fully closed (with vacuum pressure applied to the throttle opener and the dashpot at rest).
Setting this throttle stop screw affects everything down the line (when measuring resistances as pictured below [ignore the red arrow] and when adjusting the TPS).
My question is:
(1) When you are adjusting the throttle stop screw to get rid of the gap, do you screw it in just enough to close the gap (not putting any pressure on the throttle lever)? In other words, does the butterfly valve inside the throttle body need to be in the most closed position possible when the throttle stop screw is contacting the throttle lever? Or does it really matter that much?
Another question would be:
(2) What does VC, VTA, IDL (I assume idle) and E2 stand for? In other words, what am I measuring with the ohmmeter?
EDIT: Answered this question here (page 24) http://www.autoshop101.com/forms/h24.pdf
Well, first off, I'm not an expert on these TPSs, but I've messed around with a few on 4Runner 3.slows and they seem pretty similar.
And nice find on the autoshop link - I learned a few things that I didn't know.
(1) Does that mean VC/E2 should give 2.5-5.9 kilohms in any throttle position?
Yes. It's a reference voltage. It looks like the VTA is a percentage of the VC, and the computer uses that percentage to calculate the throttle angle.
So my first hunch is that the computer won't be able to read the signal correctly with the control voltage wrong. I'm sure you've re-checked it, but are you SURE you're getting a short between ground terminal and the VC terminal?
It seems odd - don't most resistors fail open rather than failing closed?
Thanks for the quick (too quick) reply, e rock.
For those that didn't see it before I edited, my original posting was asking what it meant when I didn't get any resistance values between E2 and VC. While I was waiting for the IHMUD wisdom to start flowing, I went out to the garage and, again, measured E2 to VC and, this time, got the reading I was supposed to (I had probably measured it 20 times before hand and gotten a value of 0.00 ohms each time).
So, I ran back to the computer to change my question.
...I learned a few things that I didn't know.
Well, at least you learned something anyway.
Feel free to chime in on the new question, too, e rock.
You have a ground short.
E2 is the ECU Ground connection as far as I remember.
To answer the other question, in my opinion the TPS is "the pickiest sensor" because it matters so much how it is adjusted as well as that it is getting a good steady ground and that all the "circuitry" of it is intact without degradation. I had hellacious problems with my 4Runner's TPS and remember spending quite some time trying to balance over the bullbar while holding a feeler gauge and two ohmeter leads and a screwdriver and the TPS all at the same time. The smallest move simply from tightening the screw could throw it out of range! Aggravating extremely aggravating to adjust even if everything else inside it is working properly.
But, anyway, I'm sure you have a ground short somewhere and that is simply a sleuthing until you see something definitely damaged somewhere, or, it is simply something internal to the TPS (don't know how to figure that out). Ohh, along with all those things being "in range" you also gotta look a lot at the "linearity" of the resistances or voltages. IOW as important as it being those particular settings at those particular gaps, it is important that as you go from closed throttle to open throttle that the resistance rises smoothly with no dips down or up and then down. One of my problems with my 4Runner's TPS was that even after adjustment it had flat spots where for whatever reason at a particular RPM (ie a different gap than exactly .5 or 1.0mm's or whatever) it would "stall" and then return with both more and less throttle! It tested totally fine at the FSM's gaps but it was out of service at the same time. Hope that helps. :cheers:
