Real Time Help Needed Birf Rebuild
Indianapolis
Trying to get the long axel seated into the axel housing is really kicking my butt. Is there some secret to doing this? Do you turn the axel as you push forward? I can't believe there is a position that I haven't tried. Have been gently using the seal as a fulcrum to position the axel in the middle of the housing as best as possible. Any advice here would be most appreciated.
First, make sure you have the flat spots lined up top and bottom. I found it helpful to rotate the front DS a little so that you set the diff spline teeth in a little different position.
Then just keep working it.
Yep. Front diff is locked. Read the FAQ but not too much there about axel install.
Just have to play with it till you get it. I remember having trouble for 15 minutes. Got up and walked away for 15 and had a beer and then it popped right back in.
If the other birf is out, try and peer through the axle to make sure there are no obstructions.
The longer one is harder because you have more weight to balance to ensure it is perfectly level in the right position to go in.
You do kind of have to lever the axle shaft into position and it really helps to have an assistant rotate the pinion slowly, and it should go right in.
Do not use the inner axle tube seal as a fulcrum. There should be an indexing ring about 4" inside of the axle tube seal. (See attached pic)
attachment.php
Do you see the indexing ring? If not, you must address the issue. If yes, then you should be using that as the fulcrum. Inspect the inner axle tube seal carefully and make sure it is not damaged and the spring is still on the inside. Use some grease on the spring to hold it in place.
-B-
yes, my indexing ring is fine so that becomes the fulcrum by default I would imagine. I think I will pull out the axel and take another look to see if I can see the hole and recheck everything. Thanks.
Something that -seemed- to help on mine the first time was to have someone else on the other wheel just shimmy the disc brake cw/ccw slowly to induce movement into differential. Then it walked itself into the gears.
IMHO YMMV
Any luck?
DougM
No luck yet. I gave up last night on it after a couple hours trying. Will try again this evening. I took a good look inside and everything seems just fine. I saw the hole it is supposed to go in to. The other side is all apart so moving it is not an option. Trying to get this done for a Toys for Tots run on Sat. Thanks again for all the suggestions. Any others?
Try and turn the axle 180 degrees, for whatever reason this did the trick for me.
I decided to do the short side and so I could get a feel for it. Went in like butta. So now the passenger side is all done and I go back to the long side. Worked and worked at it to no avail. I assume that with it centered horizontally, it needs to be pivoted upward. Can someone tell me how far you push down on the end to get it to come up to the exact point. There is only so much room to work with between the birf and knuckle housing. I can only push down about 3/8 of an inch and I don't think I am getting the axel up high enough. Thoughts?
It's a feel thing and you need an assistant to rotate the pinion while you do it. Often just a couple of rotational degrees is all you need.
I got it. Finally. I wasn't pushing down enough. Thanks for all the help.
