REAL TIME HELP front wheel bearings
I have never repacked and set a front wheel bearing tightness. How much grease? And how do I know that it is tight enought, but not too tight on the 54mm axle nut?? THANK YOU
Brian
As far as grease goes, use enough to fill 3/4 of any cavity. Squeeze it into the bearings for a good ten minutes each by work the bearings and the grease in the palm of your hand.
1. Put on the thrsut washer.
2. First axle nut (flat side in first).
3. Torque to 43 ft-lbs.
4. Turn wheel each way three revs.
5. Check torque at 43 ft-lbs.
6. Loosen just enough so that the nut can be turned by hand.
7. Re-torque to 1/2 ft.-lb (6 inch-lbs.).
8. Use a fish scale (a digital one is nice) and gradually pull on a wheel lug (bolt) until the wheel rotates. It should be at 6 1/2 to 12 1/2 lbs of force.
9. Put on the lock washer but do not bend the tabs yet.
10. Put on the second lock nut.
11. Torque this one to 47 ft. lbs.
12. Spin the wheel both ways three times and re-check the torque.
13. Re-check the pulling force with the fish scale on a wheel lug bolt (again, 6 1/2 to 12 1/2 lbs to get the wheel to rotate).
14. Find tabs on the lock washer that are nearest to a flat spot on the lock nuts and bend one of the tabs on to the inner and bend the other one on to the outer lock nut.
Hope this helps.
I don't use the fish scale dealeo but just torque the inner nut to 10 ftlbs and then rotate the hub and repeat until the torque stays at 10 ftlbs after the rotation and then place on the locking ring and torque the outer nut to 47 ftlbs.
In my opinion, that's pretty shaky advice, unless I'm misunderstanding. The normal procedure is to torque the inner nut to around 50ft/lbs, rotate the wheel (IIRC), then back off the nut and re-torque using the fish scale method. The initial hard torque helps to set the bearings nice and tight, as I understand it. The fish scale makes sure the bearings aren't too tight. 10 ft/lbs on the nut doesn't say anything about the bearings, especially if they weren't seated properly. Hate to dispute the suggestion of a respected forum member, but I'd feel remiss if I didn't challenge this advice before a bunch of less-experienced folk take it as gospel. While I agree that an experienced shade-tree mechanic can set bearing loads reasonably well without a scale, I'd not be recommending it, nor skipping the initial heavy tightening, to someone who hasn't done the job before.
As far as grease goes, the most important thing to accomplish is to 'pack' the bearings. In other words, every crevice between the bearings should be completely packed with grease. The extra grease in the hub is just that, extra. It won't migrate into the bearings by itself.
-Spike
I used Landtank's method three weeks ago, and just drove over 5000 miles across country in the past two weeks. It sets up the bearings perfectly in my opinion. No problems at all. What do you trust more, a $10 WalMart fish gauge or an expensive torque wrench?
You might think so, but many of us have had to go back and retighten the locknut, after following the FSM procedure to a tee. I don't know really why this is, but it is.
I think the original post was asking about how much grease to pack in the bearings, and some of the replies are about the knuckle. There should be grease in an around the rollers. I handy way I've picked up here, is to put a glob of grease into a ziplock sandwich bag, and toss the wheel bearing in, zip it up and work the grease in through the rollers by pushing it into the palm of your hand. Keep doing it until the whole thing is pretty well lathered.
:beer:
Rookie2
Just did it last week and 10ftlbs is the magic number that works every time like landtank suggested. Trust me, I double checked his method with fish scale and it falls right around 9 lbs which is between 6 - 12 lbs factory manual calls for. So next time, I won't even bother with fish scale...
A combination of both, along with a procedure that guarantees that the bearings are fully seated. Also, the $10 fish guage allows you to re-check the bearing pre-load after the lock nut is torqued. I've seen lock washers that deformed and allowed the inner nut to be tightened too much. I've seen bearings that mysteriously loosened down the road. I've seen arguements for and against tightening bearings by 'feel'. All I'm saying is that following the procedure in the FSM guarantees the correct pre-load, and doesn't rely on the inconsistencies of grease, thread tolerances, press techniques, and whatever other circumstances might come into play, and especially for someone who has little experience with bearings.
I'm not saying your wheels are gonna fall off in six months (although I'd check them in 3, if I were you ;) ), I'm saying that there is a foolproof method for this job and it's not even difficult. I've done many bearing re-packs on various cars over the last 25 years using a torque wrench and 'feeling' the preload. I never had a wheel fall off. I never felt real good about it though, and since I found out how to do it 'right', I feel a lot better about it.
On the flip side, I have seen Toyota (way oversized) bearings trashed, and I am fairly confident the cause was too much or too little preload, whether from the initial setting or because the bearings weren't fully seated and then loosened over time.
To be clear, I'm not telling you or Landtank to change your evil ways or suffer, I'm just saying that giving this kind of advice to someone with little or no experience with bearings isn't a good idea.
-Spike
The torque wrench is used in conjunction wtih the fish scale.
thanks for all of the help, I torqued it to 43lbs, and backed it off, and than tightened the second locknut to it, I will check this week after it gets a few miles. What are the indicators if it is not set right? What will it do? Want to make sure the wife is aware and able to recognize if something isn't right. SO what should I tell her to be ready for if it isn't torqued and set correctly?
Brian
You can check by grabbing the wheel at 12 o'clock and pushing to and fro to see if there is an play, or pull your wheel and brake caliper and put fish scale on it to check that it is at spec.
You would need to remove the drive flange as well to get a reading with the fish scale.
If the bearings are loose, they will beat themselves to death. If they are too tight, they will cook themselves to death. Check for excessive heat around the grease cap after a decent-length drive, as well as the push-pull at 12 and 6 method with the wheel off the ground for looseness.
Wheel bearings are cheap, but if they fail they can take the spindle with them. Not so cheap.
-Spike
