Real time help: front brakes...
NaterGator
On Gilligan's Island
Gainesville, FL
:o Boy do I feel sheepish.
I bought some new pads for my LX because my old ones were making a racket. I also had the JOY of buying a new 3.5ton jack, jackstands, micrometer, and torque wrench... but I didn't read the FSM thoroughly before I went to the parts dept, and didn't notice I need "brake grease". Ironic that the guy ripping all the FSM links doesn't read the FSM, isn't it. :flipoff2:
Anyways I feel really stupid for asking this, but I normally just pay and have my brakes done (quicker and I'm usually in a rush) so I don't know of this mystery brake grease. Is this some specific grease I need from toyota to put on the anti-squeal shims, or does something like white lithium grease work? I feel kinda stupid for putting grease on my brake components in the first place. :grinpimp:
Thanks, and try not to give me too much noob flak! :flipoff2:
-----Nate
I never use the stuff. IIRC it is to keep brakes from squeaking. Anyway, I just put new pads in and go.......and my brakes squeak.
Agreed - or you can visit your local auto store and there's grease specifically for this application of you want to get really anal about it.
It's typically referred to as brake caliper grease and you can buy it at any autostore in a little plastic pouch for 1 to 2 dollars. There's enough in the little pouch to last you a while. You'd rather just put it on and not have to second guess it if you get squeaks, but your wheel won't fall off if you don't.
:mad: :mad: :mad: :mad: ****ign tire shop!!!
They neglected to mention that they chipped the edge of my security lug nut off my USDS wheel! Stupid idiots using an impact wrench with security lugs!
So now I have new pads on my USPS, but my USDS is totally borked and I dont want to ruin the security bit I have by trying to remove the broken lug nut.
What to do, what to do? If I take this to a tire shop can they get the lug off, or is there another more simple solution to getting that fawker off? I'm sure it is on there wayy too tight because the rest of my lugs were extremely tight and difficult to get off.
Help?
EDIT: Off to sears to buy a bolt out... screw this tire shop!
Yes. Tire shop can pull the lug in 3 minutes or so.
They have a tapered socket that they pound on with a 2lb hammer. Ruins the lug nut, but that isn't an issue now.
Get rid of the security lugs. Any rim thief with a jack and lug wrench is going to have one of the pound on sockets anyway.
Searched and read the threads, etc. The tire shop made it up to me and got it off at no cost, they were very nice about it.
They said they probably fractured it and didn't realize, and that it happens with toyota wheel locks pretty often.
Edit: just finished the USDS brake pads. They were worn unevenly... I'm gonna get micrometer measurements, but the tops were more warn than the bottoms (and they were reversed, left was on the right and right was on the left, so I put the new ones in correctly.)
Are you using OEM pads... cause I don't see that you could put them in on the wrong side. They can only go in one way unless you put them in backwards (in which case you wouldn't be able to slide the pins in and the pad curvature wouldn't match the rotor) or put them in on the wrong side rotor (which you'd have metal against the rotor instead of pad against the rotor.)
Maybe I'm totally missing something here, but I don't think so.
:beer:
Rookie2
The pads are fairly symmetric when flipped, so you could invert a right pad and install it on the left. The brass clip which appears to be a crude guard to keep rocks or debris out of the pad would then be at the top of the pad and ineffective, but as far as I could tell that was the only difference.
The whole thing goes back to the need for referring to port and starboard though, left and right is so relative and ambiguous.
The brass clip which appears to be a crude guard to keep rocks or debris out of the pad ....
Nate,
It sounds like you are describing the little clip that touches the rotor when the pads are worn. That can go on any side. The pads are not left/right.
-B-
Ah, that would be it then!
They have a stamped L and R on pads so I tried to stick to it, but it also didn't really seem to matter, the pads went in and my brakes feel better! I can see how after you've knocked it out once it is easy to quickly do the pads again, although I must admit I don't know wth the FSM was thinking with the "compress pistons with hammer handle or similar" bit... no handle hammer would fit in there and it took a bit of improvisation and doing one at a time, sticking the new pad in, then the other, then fully inserting the pad to get it done, but it worked and I'm happy.
:beer:
Rookie2
You can install them backwards, as the ones on mine were backwards when I got my LX :doh:. The pad is still touching the rotor, but the pad is "curved" the opposite direction than it should be.
That would explain the uneven wear I was fretting over on the incorrectly installed pads.
Smart bunch you guys are.... :D
I would atribute uneven pad wear to caliper pistons sticking. If the top piston is a little stuck the hydrolic fluid will throw the bottom piston harder than the top one, and vice versa.
When I open up the calipers I usually stick a c-clamp in there and use the screw to squeeze the pistons down for me.
Also I second that comment on getting rid of the security lugs those things SUCK! And usually what I do is weld another lug nut onto the end of the security lug. If you are afraid of people stealing your wheeles put new studs in there and then put a 4' pipe on the end of a breaker bar and crank the hell outa those nuts. theifs will have to throw an impact wrench on em to get those suckers off. (dont do this with aluminium wheels)
Don't do that. Torque them to 76 or 109ft-lbs, per spec.
Agree with Ben. Don't overtorque any fastener, but especially the ones that hold your wheels on. Bad things happen when they fatigue and fail. Usually these bad things happen fast.
DougM
Don't worry, I'm not going to do anything crazy :D
I'm driving around with 5 lugs on my front left wheel until toyota gets my 4 new lugs in... not too thrilled about it but there isnt much I can do. I'm not worried about anyone stealing my rims... if anything maybe my 33s but even still I doubt it.
The pads can be inserted so that the little squeal-doohinkus-pad width indicator can be at the top or the bottom. The first time I did the brakes it took me some time, but in the FSM it has those squeal things on the bottom, so then there is only one way for the pads to go in that way. The L and R stamps on the pads are what threw me. Does it mean left and right in terms of rotor or entire car? I can't remember now (per wheel I think), I just get them set up so that squeal thing is pointing down.
I use this spray anti-squeal grease that was recommended to me by a cruiser mechanic that I trust.
Ross
I have put a couple of sets on the 80 and never noticed these markings. I just orient the pads with the wear indicator in the correct place. I thought it was a clip-on wear indicator and could be moved.
-B-
I have probably changed brake pads on our old 80 and our new FZJ80s a dozen times or more total. I've never noticed a left or right brake pad. For each pair, one has a squealer and the other doesn't. I've been putting the squealer on the inside pad, but from what I can see it shouldn't make a bit of difference. The individual pads appeared fully symetrical to me.
So you're telling me that the layer of material on the brake pad itself is directional like a bias ply tire? In that case we would need markings for left, right, inboard, outboard.
Is this the case on the fronts only or the rears too? For the rears, I just pull them out of the box and snap them in.
