Real Time Help - Engine won't start
Between pixels
I finally wrapped up my dual battery/alt upgrade install after a week with the truck parked in the garage, and when I went to start it, the engine didn't start. The starter battery had lost it's charge sitting on the concrete floor for a week, so I decided to use my newly installed second battery to start the truck. The second battery was good to get the engine to crank, but it still wouldn't start. So here's is what I had done when I installed my battery isolator and 130 A alternator:
1. Ran a 4 ga wire from the alt to a 175 A fuse block. This was then connected to the "A" terminal on the isolator.
2. Removed the large wht wire that originally ran from the alt to the fusible link block and used it to replace the original wire (blk/blu) that ran from the fusible link block to the under hood fuse block. So now one end is connected to the fuse block under the hood (main conn), and the other to the large terminal on the fusible link block.
3. Cut the smaller wht wire that originally ran from the alternator, added an extension, and connected this to the smaller terminal on the fusible link block.
4. Created a new wire that has one end soldered to to the three leads from the fusible links. Two of the fusible links (F6 & F8)terminate in ring terminals that are connected to the large terminal on the fusible link block. The third fusible (F7) link terminates in a connector and just reconnects to the existing stk connector. The other end of this wire was connected to terminal #2 of the isolator.
4. Created another new wire that that runs from the smaller terminal on the fusible link block to terminal #2 on the isolator.
4. Spliced into the "IGN" wire that runs to the alt, and added a lead that runs to the "IGN" terminal on the isolator.
I have now removed my second battery and the large gauge wiring and switches associated with my second battery, and reconnected all power leads to my starter battery which has been recharged. I can crank the negine over now with my starter battery but it still won't start. I believe I am getting power to the engine ECU, after confirming I'm getting +12V at the EFI fuse on the fuse block which sends a +12V signal to engine ECU.
I have the Lexus wiring schematic manual, and I have checked as much as I can think of.
I would like to avoid having the truck flatbedded to the Lexus dealership (CAN$106.00/hr):crybaby:, so any advice as to what I should be checking would be much appreciated. Schematic attached.
a battery discharging because it was set on concrete is a myth.
The simplest answer is that your security system might have set itself. Try locking and unlocking the door with both the fob and the door key.
Perhaps so, but all I can say is that I purchased the OEM Toyota battery 13 months ago, and it was charged when I removed it, and wasn't strong enough to crank over the engine after sitting on the gargage floor for a week.
Thanks, I will try this once I get home.
I'm not big on the dual battery thing but I think your problem is with the fuseable links. I know if they aren't attached to the battery in a single system the engine will crank without starting. In your diagram you have them attached to the 2nd battery.
After spending lots of $$$ and all last week (20+ hrs) on trying to get this wired up I would tend to agree, but I started down this path, and will follow it through. I would recommend against it to others unless they can actually justify the need for additional electrical demand/ supply.
Could you please elaborate on your statement regarding the fusible links? I have removed my second battery, and the fusible links have now all been connected back to the positive post on my starter battery, albeit by two separate wires from the fusible link block.
Have you read through this info: https://forum.ih8mud.com/80-series-...es-faq-item-recommend-keeping-copy-truck.html ?
Fusible Links and Relays
Below is a list of fuses and fusible links and relays critical for engine run, this is taken from a 96 LX EWD, should work for 95-97 I would imagine 93/94 would be similar.
There are three fusible links near the positive post of the battery, all three are needed for the engine to start and run, they look just like wires as that is basically what they are, they are intentionality weak wiring that melts with too much current, a blown one may melt in half insulation and all and smoke a lot, or the insulation may just look bubbly and melted on the surface but still look attached, or may look just fine from the outside but be severed inside
The three come from Toyota as a set, all three are replaced at the same time, they are cheap, everyone should have a set in their glove box, and everyone should also carry an assortment of regular blade fuses also,
"Main" Fusible link, critical as it is upstream of the 15A EFI fuse under the hood, you can test this one from the drivers seat by turning on the radio, headlights, ac/heat fan, defrost, stop light, tail lights and telephone, if any of the above work then this fusible link is good,
"AM1" Fusible link, critical as it is upstream of the ignition switch and provides the power for to the starter solenoid, you can check this one from the drivers seat by checking the horn/hazards, dome light, diff locks, rear heat, turn signals, cigarette lighter, or wipers,
If you have the hazard & horn but none of the others check the big 50A AM1 fuse in the under hood fuse box (50A AM1 fuse not to be confused with the AM1 fusible link) Might not be a bad idea to stock a 50A fuse incase the big AM1 fuse blows
"AM2" is probably the most engine centric, it provides power to the ignition switch, the injectors, the igniter, the ignition coil, the distributor, and the alternator control system, if you get the yellow light on the volt meter with “key on engine off” this fusible link is good,
There are only three critical regular sized fuses required for the engine to start and run
15A EFI located in the under hood fuse box
7.5A Ignition located in the fuse box at the drivers knee
15A ECU-IG located in the fuse box at the drivers knee
You should stock at least some 15A and 7.5 amp blade fuses if not a complete set, but those two sizes are what you need to limp home.
It sounds like you are not getting power to one of those three critical fuses. Can you check them and see if you have 12V on one side, and continuity across the each of those fuses (sometimes a visual check won't show a blown fuse). Also check the continuity across each of the three fusible links. Let us know what you find!
Thanks Adam.
It turns out that the 7.5A for the IGN was burnt out. After this was replaced the engine fired up no problem. A fellow mudder came by my place Tuesday night and was able to diagnose the blown fuse even though I had visually checked all fuses (pulled each and every one) a few days prior. I could have blown it in the interim, as on Tuesday night we were able to get the engine to fire (e.g. spark) but not start even with starting fluid (so I doubt the fuse was blown at that point it). We did diagnose that the ECU was not getting power, and the EFI relay was not closing.
Even though it now starts, I believe that there was some other gremlin at work.
Thanks to all for the input, and once again this forum is one of the best out there, as I probably saved myself $1k but not having to take it to the Lexus dealer.
