So here is an interesting problem. I put my crank pulley back on and it lines up just fine with the alt pulley. The water pump pulley is a whole different deal. It sits back a smidge to far. I put 1 washer per bolt back there to try to shim it up but it still is off. Not a great deal mind you but enough that I am asking about it. I can't put any more washers back there to shim up the pulley because then it won't mate right to the pump. Any ideas? Suggestions? WTF happened?
