Real Time Help Before It Rains Again
Carpinteria, CA
I just moved my driverside floor mat to discover a carpet that was soaked with water. It has been raining here off and on for about a week or so and I just noticed the water now. I pulled the carpet back and it seems to be localized to that part of the rig. Any suggestions? im in the process of trying to determine if my sun roof drains are clogged.
Thanks for the help
Paul
Could be your windshield leaking in and running down behind the dash. Or it could be moonroof drains. Is your headliner wet? Just open the moonroof and pour some water into the pan on the drivers side front, and see if it drains out of the rocker panel. And do a search too, this has been discussed at length a lot of times for both scenarios.
Had the same deal, but on the PS carpet. Looked like a windsheild seal leak but as mentioned above, put water down the sunroof drains and witnessed it coming out of the liner and down onto the carpet. A little wire reaming down the tubes cleared it right out. :)
thanks all. I should have known better then to ask before I searched but I panicked. Anyway both drains were clear but it was coming down the edge of the headliner like a clogged drain would do. the PS is a little damp as well. Im not so sure that it isnt a problem with the sunroof sealing like it is supposed to. Im in the process of trying to get the carpet dry right now. I tried clearing the drains out anyway. I will keep everyone posted on what I find when it is light again.
Sounds like your moonroof drains then if your headliner is wet. Even if the glass itself isn't sealing good anymore, you still should not have leaks. Any water that gets by the seal will go into that big pan, then drain out via one of the four drains. When you say both drains are clear, do you mean that water freely flows out of them and out of the rocker panel? I would still try pouring the water in slowly to check each drain individually. I just dealt with this on my 94 a couple weeks ago, I ended up having to run a new hose cause mine was burnt for some reason and was melted shut! My glass seal isn't. But no leaks so far now.
If it is the moonroof, you can get some weedwacker cord and fish it down through the drain tube. I also attached it to a drill and gave it a few spins.
You also might want to pull one of the black rubber plugs out of the bottom of your rocker panel so that the water drains out faster. Be careful you might get wet when you yank it out. ;)
are there other drain tubes besides the two in front? I have poured a bunch of water down the tubes and it comes out fine. I closed the sun roof and went for a drive in the rain and the floors had water in them again. The headliner looks fine(no water damage). what should I look at next? I will continue to check the searches
Thanks
Two in front that you saw, and two in back that exit behind the rear wheels. One on each corner of that moonroof pan. But if you cleared your drains, and they are draining fine, and no wet spots on the headliner or A pillar, but your carpet is getting wet again, check to see if your lower windshield seal is leaking, running down behind the dash, and pooling on the floor. Especially check the corners of the windshield. Or maybe there is a plug in the floor pan that is missing?
I figured it out i think. I had my wife spray water all over the cruiser and saw that there was water coming out from the windshield gasket. So now my qoustion is How much are those things to get repaired? any advice on getting the leak fixed until i can get it fixed for good.
Thanks
I had my windshield replaced for about $200. You want to get an Toyota OEM gasket, no good as use the oem. In searching on windshield replacement, you will see the need to glue or use adhesive ( I don't remember) on the gasket. Some windshield places will tell you that it isn't needed and then you windshield will leak later on.
If your windshield is OK, you might just have them pull it out and replace the gasket with adhesice (remember to serach to find the correct solution).
