Real time Birf help needed
Only an idea, not a tested solution but what about the possibility of drilling and tapping a hole in the bottom of the axle tub where a long bolt could be inserted to act as a fulcrum much like the function of the original baffle. Being threaded you could easily make adjustments in height to get the axle properly positioned. Once the axle finds it home remove the long bolt and replace it with a short bolt just to plug the hole. I would drill the hole a little further inboard from the position of the original baffle.
Ppc, good thought and is being considered. My father in law thought of the same thing.
Obviously if it had been the short side things would be easier, I don't know that the short side has a baffle though, but of course it's the long heavy side.
I don't know if this is a crazy idea or not, but could you remove the axle breather fitting and perhaps feed a stiff wire/coat hanger through there? Not sure if you can make a loop that can be used to support the long shaft but desperate actions and all that!
Alia176, considering this idea as well since the whole is there already. Probably will try this first before any other ideas.
Im at least glad several minds are coming up with the same ideas. They cant be too strange then.
1. do it without knuckle or seal set the splines and keep that position
2. install knuckle not seal ( but seal on the shaft )
The idea it's you can use some small block as leverage to get " in " then you remove it, install the seal and put it all the way in.
I never had to get to this point since setting splines before makes the hole process much more easier and yes, sometimes you need to put some pressure / leverage on the seal .. no other option.
Thanks tapage. Do you mean setting the splines of the axle to the differential? Inserting enough just to get started?
Im away for a few days now but will get back on it next week. Will have, some more time to study on it.
yes set it without knuckle to the correct position ( depth ) then remove carefully the hole axle birf assembly .. you will know that at this position it will go in ..
It seems my trouble is getting the end of the axle up into the diff since I don't have the baffle to help locate the axle insertion.
I didn't have the baffle neither ..
Tapage, taking the knuckle off worked like a charm. Gave me just the room I needed to tilt the axle up and in the diff. Took all of 3 seconds to get it installed. Thanks!
