Real time ac compressor help
Houston, Texas
I was replacing the clutch and I am sure I busted off the end of the nose cone. :bang:The compressor is good and am positive the noise was from the pulley and not the bearing.
I searched and from what I read, everyone this has happened to ponied up for a new compressor but, I didn't read where anyone asked if there is a way to replace the nose cone?
So what's the verdict?
Buck
Buck,
This something you can pull off a used one?
Ken,
It looks like the nose cone is part of the front cap to the compressor. It's hard to tell since the stator is still on. I checked the fsm but didn't see anything on rebuilding the compressor.
I'll keep researching.
Buck
Ps I am coming to Colorado for a backpacking trip. Ill be posting up in the Rising Sun forum with some questions.
Bumpity bump bump.
while you're there waiting, bored, for an answer (I don't have one, sorry), maybe you could tell us what you did wrong, to save the next guy some headaches? TIA
I don't think I did anything wrong per se. Here is what I did learn. Once you remove the short bolt that holds the pressure plate on, you need an sst bolt that threads into the plate and applies preasure agaisnt the pulley to force the plate away from the pulley. One of the compressor bolts works perferct. In the fsm it staes to tap the pulley off after removing the snap ring. I sprayed some wd 40 and let it sit for a bit. The tapping with a small rubber hammer is what busted off the end of the nose cone. If I were to do this again, I would use a gear puller to get the pulley off rather than tapping. I believe that would prevent the nose cone issue.
Buck
You will need the front end of the case, the nose is not a separate part. A junk yard will probably not sell you just the front, but a rebuilder/remanufacturer might. If memory serves me correctly, it is a Denso 10PA17C. I know of a place that might have the front.
Let me know if I can help.
