Real Time: 71 and 72 tubs are they the same?
It's got to be close, I just put a 76 tub on a 71 frame with no issues.
yes..
Hi All:
The body tubes up to the 1979 model year are pretty interchangeable - just minor differences. If I remember correctly the 1968-72 tubs are identical.
Good luck with the project - I did it on my rig 2.5 years ago.
Regards,
Alan
Depending on the month of the 1972 tub, the steering column mount and ignition switch location could be different.
It's 11:25 pm, so I'm just a little fuzzy on all the production changes. Louver vents like Living in the Past mentioned definitely stands out as one. You lose the courtesy light hole and TP eyelet holes that came with a lot of the 71s.
IIRC, the biggie was moving the fuse block from the firewall to the A pillar. Could be a hassle dealing with rehanging the harness.
Best
Mark A.
