Re-Tacking up sagging head liner
Berthoud Colorado
Website
www.w2m.com
I have approx. a 2 sq. ft. section of my origninal headliner sagging in the front.......I am thinking I can use a suringe of adhesive and simply squirt some in behind the liner and prop up a support untill it cures and do one small section at a time...
anyone think this might work, or ever tried it...
thx,
Rick
What about 3m spray adhesive?? you might try to take the nozzle off of brake cleaner or WD and put it on the adhesive can. That way you can use the straw and spray a larger area at once. Prolly be a lil cleaner that way.
I re-glued the headliner in a 40 I had years ago. I took the top off first, flipped it over then glued the liner in and let gravity help hold it in place.
works for awhile than drops back down, I treid this last year on my 82, just the DS rear corner is drooping.
Mine kept falling down. When I had the top off last time I pressure washed the inside and scraped all the crap off the lid. Next year when I have my FJ painted I'm going to spray it with Line-X bed coating. I think that would look pretty good. I also think it should silence the noise some.
