RDB for FF axle option?
Make your own, thats what i did. Take a semi float bracket copy the plate where the caliper mounts and the design the rest of the bracket to weld directly to the housing. Then cut out with torch or plasma whatever you have.
Note: you will have to get the FF hubs turned down about .150" to clear the rotors
Hey all,
Can anyone recommend any solutions for adding RDB to a FF rear axle? I am aware of SOR's RDB package...any comments on it?
Thanks for any info.
I think raddcruisers did a full float DB on a 45, 2 years ago. maybe search. I think they used Toyota stuff from a front end, but that it only worked on fullfloats not semi floats.
Not sure if this is what problem he had, but I just completed a FF swap under my 40. I had Chevy rotors and calipers on the 40. In order for the Chevy rotors to fit properly onto the FF hub, I had to grind off a small amount from the FF hub where it slides inside the rotor. I also made a slight bevel on the face of the hub as the inside of the rotor is not a 90 degree angle. Easy enough to have someone rotate the hub while you sweep the grinder across it. Doesn't take much, but you can tell when the rotor fits as it lays flat against where the wheel studs are.
Jerry D.
"so you ground the wheel hub, and didn’t get the rotor hole opened up by a machine shop???"
In a word, yes.
Perhaps the area where I ground is not clear. The hub (see picture) is about a half inch thick where I did the grinding. It’s the backing for the rotor, not the center of the rotor. The hub, and this is a guess, is about 1/4 to 5/16 inches thick and approx 6 inches in dia. And as mentioned, keep the rotor rotating while sweeping the grinder over this area and it came out fine.
Jerry D.
Please expand on this....
Just like post #10 shows except i turned mine down on a lathe. I am using '91 chevy truck rotors and '78 caprice calipers so it may work diffrent for a different setup.
