I'm waiting for the Monstaliner to show up in the mail, so to pass the time, I took the rear slider windows apart. I took them out a long time ago, which was so easy, I'm not sure why they didn't fall out while I was driving down the road. Anyway, here's a rundown:
First, I took the four little screws out around the center pillar thingy:
Then I had my tough 11 year old help me flex the frame out enough to pop the inner piece of glass out. Then I had to pull all of the rotten rubber seal out and gently take the center pillar out so I could get the outer glass out.
Then I scraped about 5 pounds of butyl off of each frame and cleaned them up with some MEK. Then I hosed them out and cleaned the inside with a tooth brush and some Simple Green.
I scuffed them up with sand paper and let the tough 11 year old primer them (she's really good with spray paint; should that worry me?)
Then I sanded and reprimed and put a few coats of Duplicolor "Dark Shadow Gray."
I have been able to find all the seals and will post more about the sources for that when I put them back together. I have NOT been able to find a source for these little rubber wedgie things and I need to get a few more, because some were missing. If anyone knows where I can get them or what they're even called, I'd appreciate the info.
