grinding when it's 99f!!Follow along with the video below to see how to install our site as a web app on your home screen.
grinding when it's 99f!!Those are 2".250 with 1.5.120 inside, but I've bent this on lesser vehicles so later on I'll be going to heretic fab for the 2x.250 in heat treated 4130.
I need $1200 in custom axle shafts and am pursuing a dual case setup, so I'm starting to pinch pennies..
This pig gets a 100 series elocker in back and a 9.5 in front.
I need a 'spare' rear axle before I cut out the rear link garbage. For the sake of only renting/borrowing a vehicle for short spurts.
I have a bunch of exhaust tubing and O2 sensor bungs to alleviate the exhaust issue. Just Leary of the noise a magnaflow or flowmaster might make(I like quiet).
That upper link is tapped for fine thread 5/8ths. I think it's a ruffstuff part?
No comment on the radius arm ignorance(Not you)
Yep, no problem. Is everything already set in place or do you have any flexibility remaining in the setup?If you have a PC handy(I can't seem to work it with a phone) can I text you my measurements for the link calc? I just eyeball this stuff when building it, but it would be cool to have a spreadsheet screenshot for posterity.
Words of wisdom right thereFlexability is usually never more than an angle grinder away. Used it a few times on my linked runner.
...via IH8MUD app
There's two bolt holes for the upper @ axle and three @ frame. I bet(guessing)they create a window of change ~20-25% for AD.Yep, no problem. Is everything already set in place or do you have any flexibility remaining in the setup?
Yep, no prob. I'm just working on a Sunday so I'm sitting in front of my laptop regardless.There's two bolt holes for the upper @ axle and three @ frame. I bet(guessing)they create a window of change ~20-25% for AD.
I'll text you in like 20 minutes if that's okay? Thanks for doing that!!
The 2nd one is rotated like 30 degrees from the first, so you have to cut and turn both. So lame. And then the flange between the two is dangley and in the way. And the primary o2 sensor can't move much closer to the body or else you'd never get it out. Toyota design on this one was pretty terrible.Sig worthy!
I'm gonna try and play the cats off as cut/welded as replacements. I'm almost merely just turning them 90* and eliminating the under frame portion. But I hear you on the strict CA specs for all this. It's like 2-3" max by the book(rearranging those items from factory) per the ref guy @ Modesto jr college
I just noticed the back one was clocked another 30 degrees or so, wtf? I removed that big 'Washer' under that body mounts bolt to sneak them in/up a bit tighter and will turn that O2 sensor somehow leaving it accessible(lol).
I bought that 4x4 innovations slider mount kit awhile back(what a Fawkin joke!!), but the skid plate can be modified and used.
I'm thinking I can explain the welding on the exhaust as replacement from the cats being smashed off-road on rocks? Bebe/Rick had there's cut/ turned and the smog tech passed it.
