Help! Have a 77 Pig that I installed new Sony CD/radio using previous wiring harness---no cutting or splicing of any other wires. Used the in harness ground connection, instead of separate ground. New unit works great, but now my dash, parking, and rear lights don't work!
Brake lights, turn signals, horn, headlights, and blower are all fine! Fuses are good and haven't had any smoldering wires. Any ideas? My first post ever, be gentle!
Dave
)also check for resistance to ground of the light sockets. they get their grounds thru their reflector metal and oxidation/corrosion can impede the path to ground. might also be a good idea to ground you new equipment directly to a ground terminal of some kind. maybe even a jumper from the battery negative post/terminal?
welcome home. where are you? and post up some pics!
