Radiator upgrade
dnp
Supporting Vendor
Jackson, MS
I need to replace the radiator in a 95 LC I'm rebuilding, and while I'm at it, I'd like to upgrade as well. I've read every thread I could find on the forum about people's opinion on what's the best radiator to use in an 80 (couldn't find a definitive thread in the FAQ section), and the general consensus seems to be to use a 93-94 copper/brass core radiator vs. the aluminum core spec'd for a 95-97. Also, for those on a budget (like me) who can't afford a T.Rad brand, many here seem to prefer Koyo brand radiators over most others. That being said, Koyo uses plastic tanks on both the aluminum core and the copper/brass core radiators they make, while CSF uses metal tanks on their copper/brass core radiators. My experience tells me the metal tanks should be superior to the plastic tank radiators.....that is, unless the CSF's are otherwise inferior products.
The threads I read didn't address this question, so I thought I'd ask if anyone of you has any experience in this issue.......any thoughts? (brands AND part numbers would be REALLY helpful!) Thanks, David
I am in the same boat, I need to replace my radiator, but I don't want to put one in that will have the same issues as the one I am taking out, plastic end caps leaking.
You have to think the metal ones are a better option. :banana:
Shop around, there are all metal 3 core aftermarket radiators out there for around $300.00. Wouldnt fuss too much about what kind of metal for that price. I prefer them over the plastic tanks.
It's my opinion that the plastic tanks work fine and their demise is due to mechanics kneeling on them rather than age or design. So, I wouldn't be concerned about the durability. If you don't do your own work I'd consider putting a pair of bright yellow "NO STEP" stickers on the top and mentioning it to your mechanic. At the end of the day, proper fit and proper interior volume and flow conditions matched to the original design of the 4.5's water flow and speed are more important. Check Cdan's price before you decide as it's a very good deal for OEM Toyota parts. They typically last 200,000 miles plus.
DougM
I was in this boat a few months back.
I spoke with a highly respected local radiator guy, very honest, old school, all that.
He said the best bet was to simply put new tanks on, rod out the old copper core and go with that. That's what I did, the core was basically in excellent condition but 40% blocked, now it's as good as a new one with new tanks and clean core. Cost was about $200 over the counter (I removed and installed).
The CSF all-metal imported radiators he'd seen leak after a few years, wasn't impressed with the quality. He did sell them, just wasn't impressed with them. Better off keeping with the original OEM style.
The plastic tanks last a long time, they're not bad. They do tend to harden a bit over the years and will eventually fail, but everything does sooner or later. Doug's right, don't put your weight on them.
In my opinion the CSF radiators are not an upgrade to stock, rather, they are a downgrade. I haven't had one in an 80 but I had one in my 4Runner and the warranty they offered then just basically meant that as long as you were willing to remove and replace another leaking radiator with your own labor or your own money, they were willing to give you another replacement. Some here have had better luck but I'd either repair the original one, or replace with a new stock one, or if you actually want an "upgrade" go with the Ron Davis Racing version for the 80 series - those are absolutely awesome. HTH. :cheers:
CSF rads are not a good LONG TERM solution. Many mudders have had them fail in a relative short period of time.
Swapping the tanks of the original is possible. When you price out the cost of the new OEM top and bottom tanks, cost of rodding, etc. The price is almost a wash for an entirely new OEM radiator. I'd stick with an OEM rad either TRAD or Koyo.
Pete
OK. So, it looks like a CSF replacement is probably not a good idea. With that in mind, it looks like to me that the best replacement for my 95 will be a Koyo copper/brass 3-row unit specd. for a 93-94. I've come up with a part number C1917. Can anyone confirm that to be the best alternative to the nearly twice as expensive T.Rad OEM unit?
replacement my whit CSF and happy with it ,csf $230.02 free S/H:)
What's lacking with the CSF and other aftermarket rads is some long term data. One or two years and "seems to be working fine" is not the same as maybe " 7 years, 80,000 miles and working fine"
I'd like to see some posts of mudders with some 5+ year data on the aftermarket rads. Problem is there isn't much out there for what ever reason.
I realize that most 80 owners are just now getting around to replacing the OEM rad due to age, etc. The OEM rads are a known quantity with a known LONG TERM track record. Many mudders have gotton well over 200,000 miles from the original rad. Can't say the same for any of the asftermaket rads, at least not yet.
Pete
Pete
Well, you bring up an interesting question: The 95 I'm rebuilding only has 117,000 miles on it. The PO NEVER (and I truly mean NEVER) changed the oil in this truck, and it digested a rod bearing or two. Accordingly, while the the engine is out and being rebuilt, I thought it'd be the better part of wisdom to just replace the factory radiator.............with only 117,000 miles on it, would I be better off having this one rodded/resealed (mine is the aluminum radiator with plastic tanks) rather than replacing with aftermarket or should I replace it? I worry a little bit about the competence of radiator shops to work with aluminum and plastic, but if these factory units are capable of being rebuilt, I wonder if that's a strategy I should consider........any thoughts from anyone?
the heater does not warm as well with a 3 core all metal after market but I have no overheating issues during the summer.
Did you put in a different thermostat or did you remove it altogether? I ask because, shouldn't the thermostat determine the temperature of the coolant in the engine (and heater core) irrespective of the cooling efficiency of the radiator?
Pete
yes, after 282,000+mi on OMErad, it time for new radiator:)
yes,.................
I mistakenly replaced the oem radiator with a csf radiator in my mini truck a few years ago when I was trouble shooting the cooling system. I now get a new radiator every couple years when it springs a link compliments of csf. I am very unimpressed with their quality. good news is that I have gotten really good at swapping radiators. Luckily that vehicle has no ac and no auto tranny line in the radiator so it is pretty easy. I would not buy one again unless I was desperate to replace the radiator in the vehicle merely in order to sell it to some unsuspecting fool.
Pretty much all that needs to be said has been however, if you use your vehicle 'off road' a lot then you need to make sure the rad is not flexing due to poor mountings and FWIW an all metal rad is easier to 'self repair' if your stranded miles from anywhere.
regards
Dave
I installed a Koyo C1917 recently in my '94.
Putting them side by side, the Koyo appeared to be an exact match to stock.
A couple of the mounting bolts are smaller, but you can re-use the original bolts.
I had to slightly adjust the position of the Koyo's 'ATF elbow tube', which was a matter of loosening a nut, adjusting, and re-tightening the nut. No big deal; took less than a minute. Out of the box, my Koyo's ATF elbow tube was angled too high such that if installed the ATF hose would rub on the fan shroud.
Too soon to provide a long term report, but so far so good.
If you get the Koyo, and if I had to do this again, I would try to leave both original side brackets in the vehicle (the excellent FAQ recommends removing US-PS bracket and leaving US-DS in place). There is a horizontal bolt mid-way through the side brackets through a rubber bushing that is a little tricky to deal with (I broke one) and perhaps better left in place.
