- Thread starter
- #21
ELW2, can you confirm that your replacement rad from Go-Part.com (Koyo C1917) was a plastic tank / copper& brass core unit? Just want to make sure before I order. Thanks.
In my opinion the CSF radiators are not an upgrade to stock, rather, they are a downgrade. I haven't had one in an 80 but I had one in my 4Runner and the warranty they offered then just basically meant that as long as you were willing to remove and replace another leaking radiator with your own labor or your own money, they were willing to give you another replacement. Some here have had better luck but I'd either repair the original one, or replace with a new stock one, or if you actually want an "upgrade" go with the Ron Davis Racing version for the 80 series - those are absolutely awesome. HTH.![]()
I installed a Koyo C1917 recently in my '94.
Putting them side by side, the Koyo appeared to be an exact match to stock.
A couple of the mounting bolts are smaller, but you can re-use the original bolts.
I had to slightly adjust the position of the Koyo's 'ATF elbow tube', which was a matter of loosening a nut, adjusting, and re-tightening the nut. No big deal; took less than a minute. Out of the box, my Koyo's ATF elbow tube was angled too high such that if installed the ATF hose would rub on the fan shroud.
Too soon to provide a long term report, but so far so good.
If you get the Koyo, and if I had to do this again, I would try to leave both original side brackets in the vehicle (the excellent FAQ recommends removing US-PS bracket and leaving US-DS in place). There is a horizontal bolt mid-way through the side brackets through a rubber bushing that is a little tricky to deal with (I broke one) and perhaps better left in place.
Did you put in a different thermostat or did you remove it altogether? I ask because, shouldn't the thermostat determine the temperature of the coolant in the engine (and heater core) irrespective of the cooling efficiency of the radiator?
