Radiator replacement
odessa, tx
Going to be replacing the radiator, water pump, thermostat, all belts, fan clutch (with 20k fluid) have a black and a blue hub, next weekend. I've already replaced all of the coolant hoses is there anything else I should do while I'm in the area? Also would you run the black or blue hub clutch with the 20k fluid. Blue is new .Black is old. I will be placing Toyota red coolant back in it and i performed a good flush a few weeks back .I think i have all of my bases covered but thought I'd ask.
Blue Hub should be fine with 20K cst. I used about 48 ml in mine and it does a good job in the same Texas heat. Sounds like you are right on track with the rest of it.
Just curious why you will be running Red? I had red in mine and recently changed out my radiator and went to green as green is way more available . I don't want to be carrying extra Toyota specific coolant in the case that I might need it whereas you can get the green stuff pretty much anywhere.
Good luck on the fix. It's not that hard at all.
Mine has this and both are proven
I may go with the green this time. I don't think it makes a difference
Red is superior for Longevity but it's getting $$$$. Like blood types it's best not to mix. If you just put in fresh, capture it and put thru paint strainer and put back in. You will be out less than $1 for paint strainer.
In the middle (old rad is out; waiting on a bolt) of doing exactly this. I've already addressed the silicon oil, thermostat and full flush so I am also replacing the low pressure power steering hoses now.
Additionally, if I had more time or resources I would replace the main crank seal and oil pump o-ring. With even more time I would replace the high-pressure power steering hose and perhaps the o-ring on the power steering pump.
But then I'd lose the main source of underbody rust prevention...why would I do that?
...should be finished tomorrow with current issues.
PS hoses
Oil pump gasket
Front main seal
#1 coolant hose under TB.
PHH
Heater valve
PS hoses
Oil pump gasket
Front main seal
PHH
Heater valve
Replaced PHH, power steering hoses and heater valve Iast year .
Oil pump gasket replaced 2 years ago by dealerneed to get that TB coolant hoses though. But ilI' inspect it all while in there.
taking notes here. can i please ask:
1. are the power steering hoses shown here? or i guess not?
2. what about the “TB coolant hoses”? what is “TB”?
3. “oil pump gasket” is the same as oil pump o ring or different?
4. is front main seal the same as main crank seal?
THANKS
I think the firewall heater hoses are worth replacing on these old rigs. I've now replaced every hose and clamp in the cooling system in my truck. It was a PITA, but I'm glad I did it.
