Radiator Repair?
Midwestern Flatlands
Just discovered the side bracket for my radiator is loose from the tank at the top. Does anyone know if this bracket was attached to the tank by solder, brazing, TIG, or ? Any luck reattaching and if so, how did you do it?
If i can't get it fixed and decide to replace, should I go for aluminum or copper/brass? 2, 3, or 4 row?
Thanks,
Pete
I used SikaPower 4720 High Strength Panel Adhesive. Worked great.
