Has anyone here pressure tested their a radiator, or have you just put it in the vehicle and hoped for the best? I've had a real rough time finding a radiator for my fj55 at a good price (less than $300). My radiator is not stock (craig's radiator stamped on the side), keeps springing leaks, does not allow for a stock fan shroud to bolt on, and has a strange sized filler neck that I've never been able to find the proper cap for. Found a replacement for around$30 from a 74 fj55 and would like to not use the local radiator shop (they did very s***ty work for me last time, had to fix the leak myself).
What's to it, will the stopcock leak pressure when open if used as a pressure inlet for testing? Also, does HCl really work good for cleaning out the radiator deposits? I've seen HCl do a number on metals with some zinc content.
