Radiator Misting spray Install
I was going to just go with windshield washer fluid without the dye. If its good enough for the windshield and being held in the engine bay, its good enough for spraying on the radiator.
If it is like windex, it is probably isopropanol not methanol. When diluted in water it will be less flammable than if 100% concentration, obviously, but when atomized should still burn. Why don't you try it using one of your nozzles at about 500psi. You may get a cool blow torch when ignited :D
Oh yeah I agree it is a good system for cooling the rad, I am just saying especially in CA with their poor fuel you should be more interested in cooling intake charge than anyone. It will surely make the A/C extra frosty though. lol
As for fire, with washer fluid I wouldn't be too worried about it, the import guys have been spraying intercoolers for years with it. Just know that methanol is bad for aluminum.
Good point. I'm wondering if I should have the radiator black anodized TypeII to protect it and help with the heat transfer? Maybe I should ask Ron Davis. Hmm....I could just anodize it at work.
Need to find the link but the stuff I found is windshield washer fluid without any dyes and it was either Ethenol or Methanol. Both of which I would just cut with water.
Keeping things simple, if you factor in the cost of meth vs water, the availability of each and any real heat dissipation advantage meth has over water, I doubt its worth the extra hassle.
Agreed, cept that every auto part store and WalMart in America has windshield washer fluid. Just not the type I'd use per se. I'm leaning towards water FWIW.
I'm embarrassed to write this here as most of this is way over my head, but my 96 FZJ80 AC works fine UNLESS I'm heading to Colorado from California in the summer loaded with gear and have to drive through the desert. AC stops after engine temps reach 229F or so and I'm using a BlueDriver to visualize the temps when it happens. Radiator and fan clutch and hoses have all been replaced, and I'm getting the impression that the situation is just one of living with the FJ80. That said, I was thinking that a spray to the radiator might help, and so I found this thread.
Sounds like you all are discussing spraying an intercooler on a turbo, whereas I still just have the stock straight 6. Will a misting of the radiator likely help me as well? Sorry for the ignorance!
No, spraying a small amount of water will provide only a few seconds of cooling. You need to fix your underlying problem.
What brand of radiator was installed and when was it installed? Same question for the fan clutch? Has the fluid in the fan clutch been upgraded to higher viscosity?
When was the system last fully flushed? Is coolant staying at proper level?
Is the system holding pressure? The radiator cap may not be holding pressure allowing the coolant to boil out.
Have you checked the engine timing. To far advanced can cause lean conditions and over heating.
Anything blocking the front grill like lights, a winch?
Any blockages in the exhaust, have the catalytic converters been checked for blockages?
No, spraying as small amount of water will provide only a few seconds of cooling. You need to fix your underlying problem.
Wow thanks for all of the input. I dont honestly know brands but I will check with the mechanic who did it. There are some obstructions to the grill such as the winch, and I moved a light bar that was blocking it, and I’m going to move the license plate that is partially obstructing... will see if that helps!
