Radiator leak- New or fixable
So I kept smelling antifreeze while driving and after inspection, it's leaking a bit from the passenger side corner through the metal tab area.
Think I could take it to a radiator shop and get it re-sealed or am I looking at a new one?
I personnaly would replace it. Sometimes thoses fixes never hold and getting a new radaitor will only improve your radiator. Probably lots of sludge in that one. I would recommend the OEM rad instead of the aftermarket ones.
I'd say definitely replace, unless you really need to wait a bit for the cash - thing is it's already perforated and any fix is going to blow just when you really need it to work properly. Believe me that's exactly what happens! :grinpimp:
If you do choose a quick-fix, here we can buy tubes of copper and some other metal shavings, which are poured into the radiator while it's running. I have a couple of buddies who have had to use it, and it stopped the leak immediately and lasted until they got home without any apparent damage to the engine, etc.
Whatever you choose to do, just make sure you don't save a few bucks to then end up warping the head!
Difficult to dispute.
I am going through that exact problem right now as well with my 91. I am replacing as opposed to repairing for dependability sake. a new radiator is expensive but i think it is well worth it.
